My laptop running Ubuntu 12.04.3 has this SMBus according to lspci:
SMBus: Intel Corporation 6 Series/C200 Series Chipset Family SMBus Controller (rev 04)
lshw command shows it as unclaimed. Which driver is needed to activate it?
Zanna
  • 72,312
Frantique
  • 8,673
The correct driver would be i2c-i801, of which Intel states that it's compatible with the Series 6 PCH: https://www.kernel.org/doc/Documentation/i2c/busses/i2c-i801
In recent kernels (2.6.12 and later), the option is in drivers/i2c/busses. From 2.6.0 through 2.6.11, the driver was present, but considered experimental.
To find out if the module is present on your system, use modinfo i2c_i801. If the module is found, try to load it using modprobe i2c_i801.
Jan
  • 12,931
  • 34
  • 39
