When I try to install missing plugins on terminal, the following output appears:
arif@arif-HP-Pavilion-15-Notebook-PC:~$ sudo apt-get purge ubuntu-restricted-extras
[sudo] password for arif:
Reading package lists... Done
Building dependency tree
E: Unable to locate package ubuntu-restricted-extras
arif@arif-HP-Pavilion-15-Notebook-PC:~$ sudo apt-get install ubuntu-restricted-extras
xangua
  • 7,277
Go to the software center -> edit -> software sources and check all boxes. I think the one you need is multiverse, but just to be sure, enable all. Then do sudo apt-get update (unless it updates automatically), now the package should be able to be located.
BIfrost
  • 56
purge command is used to remove the component with all its dependencies. If you want to install the package use the following command in terminal
Anandu M Das
  • 2,303
