I am trying to install UBUNTU 14.0.4.1 LTS along with Windows 8. I've followed this question and done all the neccesary steps, How do I install Ubuntu alongside a pre-installed Windows with UEFI?
Specs:
  • Toshiba p75-A7100
  • Came installed with Windows 8.
I've done this:
  • UEFI is enabled
  • Secure boot is disabled
I am trying to install Ubuntu from a live CD. The installer gets stuck at Prepare to Install phase with below stack trace in debug.
(process:4250): dconf-CRITICAL **: unable to create file '/home/ubuntu/.cache/dconf/user': Permission denied. dconf will not work properly.
(process:4250): dconf-WARNING **: failed to commit changes to dconf: Could not connect: Connection refused
(process:4263): dconf-CRITICAL **: unable to create file '/home/ubuntu/.cache/dconf/user': Permission denied. dconf will not work properly.
(process:4263): dconf-WARNING **: failed to commit changes to dconf: Could not connect: Connection refused update_release_notes_label() update_release_notes_label() /usr/lib/ubiquity/ubiquity/frontend/gtk_components/nmwidgets.py:18: Warning: Source ID 512 was not found when attempting to remove it GLib.source_remove(self.timeout_id) /usr/lib/ubiquity/ubiquity/frontend/gtk_components/nmwidgets.py:131: Warning: Source ID 578 was not found when attempting to remove it GLib.source_remove(self.rows_changed_id) Exception caught in process_line: Traceback (most recent call last): File "/usr/lib/ubiquity/ubiquity/filteredcommand.py", line 145, in process_line return self.dbfilter.process_line() File "/usr/lib/ubiquity/ubiquity/debconffilter.py", line 287, in process_line if not input_widgets[0].run(priority, question): File "/usr/lib/ubiquity/plugins/ubi-partman.py", line 2977, in run size = int(parted.partition_info(p_id)[2]) File "/usr/lib/ubiquity/ubiquity/parted_server.py", line 220, in partition_info self.open_dialog('PARTITION_INFO', partition) File "/usr/lib/ubiquity/ubiquity/parted_server.py", line 141, in open_dialog self.error_handler() File "/usr/lib/ubiquity/ubiquity/parted_server.py", line 112, in error_handler exception_type = self.read_line()[0] File "/usr/lib/ubiquity/ubiquity/parted_server.py", line 74, in read_line line = self.outf.readline().rstrip('\n') File "/usr/lib/python3.4/codecs.py", line 313, in decode (result, consumed) = self._buffer_decode(data, self.errors, final) UnicodeDecodeError: 'utf-8' codec can't decode byte 0xd5 in position 66: invalid continuation byte Exception ignored in: <bound method PartedServer.del of <ubiquity.parted_server.PartedServer object at 0x7f86ed2fbf28>> Traceback (most recent call last): File "/usr/lib/ubiquity/ubiquity/parted_server.py", line 62, in del self.close_dialog() File "/usr/lib/ubiquity/ubiquity/parted_server.py", line 148, in close_dialog self.sync_server() File "/usr/lib/ubiquity/ubiquity/parted_server.py", line 132, in sync_server with open(stopfifo, 'w'): PermissionError: [Errno 13] Permission denied: '/var/lib/partman/stopfifo'
Kulfy
  • 18,154
Aravind R
  • 101
Ok i want to post the solution here so some body else finds it useful..
The issues were
  1. I cloned my orginal HDD to my new SSD for windows 8 and then tried to install UBUNTU on it. Not sure what happened but that triggered some permission issues that causes the Installer to crash. So dont create a clone of your windows 8 rather use a recovery or an orginal CD to create the partiotions and install windows.
2.once you are sure that windows boots up. Dont tamper with partitions you dont have to and also if using 14.0.4 LTS.. just disable fast boot. rest every other configurations on bios is fine.
  1. follow this link
http://www.everydaylinuxuser.com/201...e-windows.html
And you are set . Am able to dual boot Ubuntu and windows and both works like charm.
Aravind R
  • 101
