I try to copy and paste in xterm.
This is generally a solved question as explained here but on my laptop (ASUS x551ma) I have problems.
I highlight a text which assume copies it to the clipboard.
The paste is problematic.
There are two ways to make paste:
  • middle button
  • shift + insert
I have a mouse with just 2 buttons and pressing them simultaneously does not work.
The only insert button I see is the one on the number zero.
When I press shift + insert I write 0.
How can I paste?
According to this image, you should have an insert key if you use fn and del. Alternatively, you should be able to use 0 as insert if you disable num lock.
However, you should be able to get middle click emulation working, I am surprised it doesn't out of the box. The traditional way is to add this line to your /etc/X11/xorg.conf:
Section "InputClass"
    Identifier "whatever"
    MatchIsPointer "on"
    Option "Emulate3Buttons" "on"
EndSection
But you can also do it graphically by installing gpointing-device-settings as explained here. In fact, that post gives various ways of achieving this.
terdon
  • 104,119
