-1
Guy actually i am trying to install Ubuntu 14.04 using a USB but while installation the option along side Windows is missing. I heard that if we have a dynamic Disk, Ubuntu will not give the option along side windows.
So please help me out in installing Ubuntu 14.04 on my system.
My system configuration:
OS: Windows 7, Intel i3 processor, 4 GB RAM, 1TB Hard Disk.
Thanks in Advance :)
Use the manual installation. Select the partition on which you want to install Ubuntu, Create partition as ext4 and mount point should be : /.
Be careful when choosing the partition, you don't want to wipe your Windows install ! After everything is finished whenever you reboot, GRUB should appear and let you choose on which OS to boot.
P.S.: You can add a swap as well if you need to. and don't forget to backup before doing the install !
