30
I'm in Ubuntu 14.04 64-bit. mount.ntfs use high CPU--40%. I have Intel Core i5-3210M. Why is this happening?
lsblk:
NAME   FSTYPE   SIZE MOUNTPOINT        LABEL
sda           465.8G
├─sda1 ntfs     300M                   Windows RE tools
├─sda2 vfat     100M /boot/efi         SYSTEM
├─sda3 ntfs     438M                   Windows
├─sda4 ntfs    97.7G
├─sda5 ext4    94.1G /
├─sda6 ntfs   263.3G /media/user/DATA1 DATA
├─sda7          128M
└─sda8 ntfs     9.5G                   Recovery
sr0            1024M
top:
  PID USER      PR  NI    VIRT    RES    SHR S  %CPU %MEM     TIME+ COMMAND
26199 root      20   0   14712   1940    684 R  45.5  0.0   3:07.80 mount.ntfs
26268 user      20   0 1255660 385524  49108 S  15.3  4.8   1:01.41 firefox
28549 root      20   0  483936 130680 109148 S  12.3  1.6  11:06.58 Xorg
26250 user      20   0  538956  30212  19316 S   6.0  0.4   0:22.58 gnome-syst+
29140 user      20   0 1579488 237416  38440 S   5.3  2.9   5:56.58 compiz
 8311 user      20   0 4833744 253740  25596 S   4.3  3.1   1:26.34 java
31864 user      20   0  671040  22512  13420 S   1.3  0.3   0:07.73 gnome-term+
   10 root      20   0       0      0      0 S   0.3  0.0   0:13.72 rcuos/2
Eliah Kagan
  • 119,640
6 Answers6
21
Changing the mount options for the NTFS partition changed the application I was using from unusable with 100% mount.ntfs CPU to fully functional. The key one to use is "big_writes", but my full list is:
windows_names,norecover,big_writes,streams_interface=windows,inherit
You'd use it like this:
mount -t ntfs -o windows_names,norecover,big_writes,streams_interface=windows,inherit /dev/disk/by-uuid/DISKUUID /mountpoint
The full list of options and what they mean on the Ubuntu manpage for ntfs-3g: https://manpages.ubuntu.com/manpages/eoan/man8/ntfs-3g.8.html
Quetza
  • 311
I'm using a raspberry pi 4b 2gb. Do you have file compression enabled on the ntfs partition? Last time I accidentally leave it enabled and it killed 3 times the performance in linux. It took me 2 full days to figure it out. not sure if it works for you.
In my case, I have Steam and my games installed on an NTFS partition. For some reason, Steam caused a lot of CPU usage on mount.ntfs (and also partly on its own). It was also unresponsive.
After killing Steam, CPU usage of mount.ntfs dropped.
Note that I already have my NTFS partition configured as indicated in the other answers:
defaults,noatime,big_writes,umask=007,uid=1000,gid=46
Didier L
  • 353
You must add line to /etc/fstab for automounting the ntfs partition
/dev/sda6   /media/user/DATA1   ntfs    defaults,nls=utf-8,umask=007,gid=46   0   0
See more details about automount ntfs in:
How to automount NTFS partitions?
Videonauth
  • 33,815
Oleksandr
  • 167
I had a similar problem and in my case the issue was that i had deleted lots of files from the NTFS partition but did not empty the trash. After emptying the trash all went back to normal. Note that the trash bin showed itself as empty until i mounted the partition and waited some time.
the only solution for me was reinstalling the OS .
