Yesterday I trying to install a package with apt-get but I regret of installing this package, but every time I want to install a new package the apt-get trying to install that package again !
How I can cancel hold packages in apt-get ?
αғsнιη
  • 36,350
MajAfy
  • 143
You may not have removed the package correctly, or apt-get got interrupted while removing the package. First, I would suggest running the following to process pending operations:
apt-get -f install
Once this is done, use autoremove to make sure there is no garbage in the way:
apt-get autoremove
Then, remove your package completely:
apt-get remove --purge [package name]
I manually removed it from folder list. I checked the path where they are about to be installed. On my part,
it's located in /etc/apt/souces.list.d/PACKAGE_NAME
I was trying to install spotify running Jessie from raspberry pi. Then 'sudo apt-get update ' was successful again.
