I recently switched from windows 8 to Ubuntu 14.04. With windows I could scroll pages using two fingers but this does not work running Ubuntu.
I have followed this guide: Enable BOTH edge scrolling and two-finger scrolling for touchpad
but the commands only gives me the message: Couldn't find synaptics properties. No synaptics driver loaded?
Any idea what to do?
Regards
5 Answers5
This instructions solved the issue for me on a Lenovo G50 + Mint Cinnamon 17
http://www.evilcodingmonkey.com/2014/01/23/ubuntu-activate-multi-touch-on-elantech/
Copy-paste (code typo fixed and a bit more of info added), as backup
First, if you aren't sure your computer was built with an Elantech touchpad, open a terminal, and type the following:
cat /proc/bus/input/devices
You should find a block containing a line looking like this one, which confirms you are on an Elantech touchpad:
N: Name="ETPS/2 Elantech Touchpad"
or
N: Name="PS/2 Elantech Touchpad"
Download this archive (from Ubuntu's bug reporting page).
Open a terminal, and follow these steps (after step 4, you will have no mouse at all):
cd ~/Downloads
sudo dkms ldtarball psmouse-elantech-x551c.tar.gz
sudo dkms install -m psmouse -v elantech-x551c
sudo rmmod psmouse
sudo modprobe psmouse
Enjoy multitouch!
berbt
  • 322
Is the package xserver-xorg-input-synaptics installed ?
If not try to install it using the terminal by typing the command below:
sudo apt-get install xserver-xorg-input-synaptics
Harris
  • 2,588
Actually I had a same problem the only solution that I come up with is just install Gpointing device setting (you can find this in ubuntu software center) and enable there touchpad settings (u can customize quite a lot there), although afterwards my right click is not working :) I'll try to figure out that also and reboot your computer after installation
sevadah
  • 31
You can also find the answer here: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1407785/comments/26
Download the file: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1407785/+attachment/4309044/+files/psmouse-elantech-x551c-G50-70.tar.gz
and then the following commands via the terminal:
sudo dkms ldtarball psmouse-elantech-x551c-G50-70.tar.gz
sudo dkms install -m psmouse -v elantech-x551c-G50-70
sudo rmmod psmouse
The latest kernel with well. Touchpad is stable and smooth
wget \
kernel.ubuntu.com/~kernel-ppa/mainline/v4.4-rc2+cod1-wily/linux-headers-4.4.0-040400rc2_4.4.0-040400rc2.201511231054_all.deb \
kernel.ubuntu.com/~kernel-ppa/mainline/v4.4-rc2+cod1-wily/linux-headers-4.4.0-040400rc2-generic_4.4.0-040400rc2.201511231054_amd64.deb \
kernel.ubuntu.com/~kernel-ppa/mainline/v4.4-rc2+cod1-wily/linux-image-4.4.0-040400rc2-generic_4.4.0-040400rc2.201511231054_amd64.deb
sudo dpkg -i linux-headers-4.4*.deb linux-image-4.4*.deb
update-grub
