I'm using Ubuntu 11.04, and I'm trying to install TortoiseHg. I've applied the PPA from TortoiseHg's website, so that apt-get can actually find it. But whenever I type sudo apt-get tortoisehg, I get this:
Reading package lists... Done
Building dependency tree
tortoisehg : Depends: mercurial (>= 1.8) but 1.7.5-1ubuntu1 is to be installed
E: Broken packages
I understand what this means: I need to install Mercurial 1.8. The problem is that I can't. If I try sudo apt-get install mercurial, it says that 1.7.5 is the latest version, which it most certainly isn't.
So how do I convince this thing to install a more recent version of Mercurial?
I tried the commands from this answer to install Mercurial, but that didn't help. It again said that Mercurial was up to date.
