I currently just have ubuntu 14.04 on my laptop. The partition for it is very large, 110.85gb out of my 120gb. I tried to resize it but I can't change it as the minimum = its maximum size. How can I change the partition size? I currently have windows 8.1 on a usb to boot but have no room with it. I was thinking is there a way I could delete ubuntu so then my ssd would be completely free, install 8.1, and then install ubuntu again? Thanks!
You will not be able to do anything to any mounted partitions, and you can't unmount the partition you are running. So, you will need to boot from a live CD or USB, and then you can do whatever you want to the disk, either shrink it or delete it.
But, if you don't care about the current Ubuntu installation, can't you just install Windows, and tell it to use the entire disk? I'm not really familiar with Windows, so I'm not sure. But I do know that if you install Windows, it will not preserve the bootloader, so you would need to know how to restore that even if you kept Ubuntu installed.
- 18,944
I think that in order for the grub to work properly with Dual Boot that includes Windows in it, you must first install Windows and then install any other Linux Distro. The other way around, I think will have problems with the MRB.
So what I am proposing to you is that since you don't care about the current Ubuntu Installation, you can do the following:
- Boot Windows from a USB.
- Wipe out everything on your SSD.
- Create a new partition and formatted in NTFS in order to install windows on it. (With your SSD size I would recommend to use 80gb for the Windows installation and 40gb for Ubuntu)
- Install Windows on the 80gb NTFS partition and after everything is installed properly, boot Ubuntu Live USB to install Ubuntu to the other partition.
- Format the other partition to ext4 and also don't forget to create a swap partition. Choosing the size of this partition is another thing, but you can take a look here.
After you do all these, hopefully you will have a dual boot working properly.
Good Luck :)
