Recently, i have installed Maverick in my old netbook with Intel mobile 945GME Video Card, work flawlessly, but the problem is plymouth.
When i boot up my netbook, the plymouth not start it just black screen then GNOME desktop appear.
Sometime there are text shown (i'm not Understand the purpose of the text, it like login in "text mode" when we press Ctrl+Alt+F1 but after second (without typing anything), GNOME desktop appear) then sometime Plymouth shown (but rare) in short duration (the plymouth even shown only in 1 second)
I'm try set the resolution from GRUB, no result.
Your Help Really Apreciated
Try the following solution that works for several intel integrated graphics types:
In a terminal:
sudo su
echo FRAMEBUFFER=y > /etc/initramfs-tools/conf.d/splash
update-initramfs -u
exit
fossfreedom
  • 174,526
Try installing sudo apt-get install startupmanager then changing the resolution and tick on the show boot splash.
Then make sure the right plymouth theme is selected:
sudo update-alternatives --config default.plymouth then choose the one that you want and then sudo update-initramfs -u
try checking /etc/default/grub and make sure the splash is enabled GRUB_CMDLINE_LINUX_DEFAULT="splash"
If you would like to customize your Plymouth theme check this out.
Hope this helps, good luck!
Vitaly
  • 901
