132
How can I get the bash to look colored like this?
colored-bash
daniel451
  • 7,613
5 Answers5
193
Open ~/.bashrc in text editor and uncomment line:
#force_color_prompt=yes
to be:
save then execute source ~/.bashrc
To Kra
  • 2,031
100
I came up with this solution:
  1. Open ~/.bashrc in a text editor.
  2. Copy this and add it at the end of the ~/.bashrc file:
    PS1='\[\033[1;36m\]\u\[\033[1;31m\]@\[\033[1;32m\]\h:\[\033[1;35m\]\w\[\033[1;31m\]\$\[\033[0m\] '
  3. Ssave the file and source ~/.bashrc:
    source ~/.bashrc
For a full list of available colors and further options, look up these links:
daniel451
  • 7,613
A version that is a bit more 'general' - should work with a varied environment:
(depends on terminfo)
Insert this in your $HOME/.bashrc:
function fgtab {
  echo "tput setf/setb - Foreground/Background table"
  for f in {0..7}; do
    for b in {0..7}; do
      echo -en "$(tput setf $f)$(tput setb $b) $f/$b "
    done
    echo -e "$(tput sgr 0)"
  done
# The prompt in a somewhat Terminal -type independent manner:
cname="$(tput setf 3)"
csgn="$(tput setf 4)"
chost="$(tput setf 2)"
cw="$(tput setf 6)"
crst="$(tput sgr 0)"
PS1="\[${cname}\]\u\[${csgn}\]@\[${chost}\]\h:\[${cw}\]\w\[${csgn}\]\$\[${crst}\] "
Then execute source ~/.bashrc.
After that, fgtab will display a color table with numbers. Those numbers are for tput setf n and tput setb n where 'n' is the number, 'f' stands for 'foreground' and 'b' stands for 'background' color.
tput sgr 0 will reset foreground and background colors to default.
And as you can see, changing the colors used for the prompt becomes really easy (just edit the same number in $HOME/.bashrc as you wish).
Add an $(tput setb n) in $cname if you wish to have ALL of the prompt with background n.
wjandrea
  • 14,504
Hannu
  • 6,605
  • 28
  • 45
I've been having trouble making "force-color-prompt" to work in Ubuntu 20 using Kitty/Putty.
But notice the following code in the default Ubuntu 20 .bashrc file: case "$TERM" in xterm-color|*-256color) color_prompt=yes;; esac
So in Kitty, go to
  1. Connection
  2. Data
Then change "Terminal-type string" from "xterm" to "xterm-color" and viola!
Ryan Kopf
  • 111
If you install the minimal Ubuntu you don't get the default .bashrc that has the values for colors and some other stuff. This is the default .bashrc you can use.
# ~/.bashrc: executed by bash(1) for non-login shells.
# see /usr/share/doc/bash/examples/startup-files (in the package bash-doc)
# for examples
If not running interactively, don't do anything
case $- in i) ;; *) return;; esac
don't put duplicate lines or lines starting with space in the history.
See bash(1) for more options
HISTCONTROL=ignoreboth
append to the history file, don't overwrite it
shopt -s histappend
for setting history length see HISTSIZE and HISTFILESIZE in bash(1)
HISTSIZE=1000 HISTFILESIZE=2000
check the window size after each command and, if necessary,
update the values of LINES and COLUMNS.
shopt -s checkwinsize
If set, the pattern "**" used in a pathname expansion context will
match all files and zero or more directories and subdirectories.
#shopt -s globstar
make less more friendly for non-text input files, see lesspipe(1)
[ -x /usr/bin/lesspipe ] && eval "$(SHELL=/bin/sh lesspipe)"
set variable identifying the chroot you work in (used in the prompt below)
if [ -z "${debian_chroot:-}" ] && [ -r /etc/debian_chroot ]; then debian_chroot=$(cat /etc/debian_chroot) fi
set a fancy prompt (non-color, unless we know we "want" color)
uncomment for a colored prompt, if the terminal has the capability; turned
off by default to not distract the user: the focus in a terminal window
should be on the output of commands, not on the prompt
if [ -n "$force_color_prompt" ]; then if [ -x /usr/bin/tput ] && tput setaf 1 >&/dev/null; then # We have color support; assume it's compliant with Ecma-48 # (ISO/IEC-6429). (Lack of such support is extremely rare, and such # a case would tend to support setf rather than setaf.) color_prompt=yes else color_prompt= fi fi
if [ "$color_prompt" = yes ]; then PS1='${debian_chroot:+($debian_chroot)}[\033[01;32m]\u@\h[\033[00m]:[\033[01;34m]\w[\033[00m]$ ' else PS1='${debian_chroot:+($debian_chroot)}\u@\h:\w$ ' fi unset color_prompt force_color_prompt
If this is an xterm set the title to user@host:dir
case "$TERM" in xterm|rxvt) PS1="[\e]0;${debian_chroot:+($debian_chroot)}\u@\h: \w\a]$PS1" ;; *) ;; esac
enable color support of ls and also add handy aliases
if [ -x /usr/bin/dircolors ]; then test -r ~/.dircolors && eval "$(dircolors -b ~/.dircolors)" || eval "$(dircolors -b)" alias ls='ls --color=auto' #alias dir='dir --color=auto' #alias vdir='vdir --color=auto'
alias grep='grep --color=auto'
alias fgrep='fgrep --color=auto'
alias egrep='egrep --color=auto'
fi
colored GCC warnings and errors
#export GCC_COLORS='error=01;31:warning=01;35:note=01;36:caret=01;32:locus=01:quote=01'
some more ls aliases
alias ll='ls -alF' alias la='ls -A' alias l='ls -CF'
Add an "alert" alias for long running commands. Use like so:
sleep 10; alert
alias alert='notify-send --urgency=low -i "$([ $? = 0 ] && echo terminal || echo error)" "$(history|tail -n1|sed -e '''s/^\s[0-9]+\s//;s/[;&|]\s*alert$//''')"'
Alias definitions.
You may want to put all your additions into a separate file like
~/.bash_aliases, instead of adding them here directly.
See /usr/share/doc/bash-doc/examples in the bash-doc package.
if [ -f ~/.bash_aliases ]; then . ~/.bash_aliases fi
enable programmable completion features (you don't need to enable
this, if it's already enabled in /etc/bash.bashrc and /etc/profile
sources /etc/bash.bashrc).
if ! shopt -oq posix; then if [ -f /usr/share/bash-completion/bash_completion ]; then . /usr/share/bash-completion/bash_completion elif [ -f /etc/bash_completion ]; then . /etc/bash_completion fi fi
