I have a pair of Bose AE2w headphones that initially connect fine with Bluetooth on 14.04. I can select the headphones and choose A2DP output, and everything works.
If the connection times out due to inactivity or from hibernation, and I reactivate the headphones, the Bluetooth connection is re-established, but A2DP does not work only HSP.
Any suggestions on how to fix this problem?
No Time
  • 1,073
I found this in other tread... it worked for me:
Had the same problem fixed it with:
pactl list cards short
to get the device id. Then I did
pactl set-card-profile x a2dp
where X is your device id.
found it by reading No A2DP streaming audio from 12.04 to Bluetooth headset
