Please read the (PS:) at the end of this new post on this specific problem.
I've read carefully This post but still have problems to connect to one of my Bluetooth headset.
I have two bluetooth headsets (SHB71150 from philips, and WeSC Piston along with two bluetooth dongles one from Thrust (bluetooth V3 version) and and Belkin one (bluetooth V4 version).
For both dongles and both headsets Philips SHB7150 and WeSC Piston BT Black I get the same result :
The dongle manages to connect to the headset, but I have no further option in the Volume control to uses the Bluetooth device.
PS : Now things are a bit different : When I try to pair (Either the SHB71150 from philips, and WeSC Piston) the little bluetooth button shows that the pairing is being done but a few seconds later, the pairing is lost.
I've read all the posts related to bluetooth and head sets bu did not find a viable solution.
Could any one give me a hand on this new problem?
Had the same problem fixed it with:
pactl list cards short
to get the device id, then I did:
pactl set-card-profile X a2dp
where X is your device id
found it by reading No A2DP streaming audio from 12.04 to Bluetooth headset
