Tried all the other "sound not working" posts i think, lost count.
purge/reinstall alsa and pulse, reboot, add user to audio group, various lines in the alsa config file such as "options snd-hda-intel model=" then tried different options like generic, auto, basic, default, etc. tried pulseaudio -k && sudo alsa force-reload a few times, with and without rebooting.
Hardware: 16gb ram, core I7-4790, Intel Haswell mboard with onboard sound and graphics Multimedia: Audio Adapter: HDA-Intel-HDA Intel HDMI OS: Ubuntu server 14.04 with ubuntu-desktop installed.
GUI sound settings lists only the dummy sound card
alsamixer -c 0
│ Card: HDA Intel HDMI                                 F1:  Help               │
│ Chip: Intel Haswell HDMI                             F2:  System information │
│ View: F3:[Playback] F4: Capture  F5: All             F6:  Select sound card  │
│ Item: S/PDIF        │
│                                     │OO│                                     │
│                                  < S/PDIF >                                  │
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: HDMI [HDA Intel HDMI], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
aplay -L
default
    Playback/recording through the PulseAudio sound server
null
    Discard all samples (playback) or generate zero samples (capture)
pulse
    PulseAudio Sound Server
hdmi:CARD=HDMI,DEV=0
    HDA Intel HDMI, HDMI 0
    HDMI Audio Output
dmix:CARD=HDMI,DEV=3
    Direct sample mixing device
dsnoop:CARD=HDMI,DEV=3
    Direct sample snooping device
hw:CARD=HDMI,DEV=3
    Direct hardware device without any conversions
plughw:CARD=HDMI,DEV=3
    Hardware device with all software conversions
cat /proc/asound/cards
 0 [HDMI           ]: HDA-Intel - HDA Intel HDMI
                      HDA Intel HDMI at 0xf7d14000 irq 46
cat /proc/asound/devices 1: : sequencer 2: [ 0- 3]: digital audio playback 3: [ 0- 0]: hardware dependent 4: [ 0] : control 33: : timer
mplayer -ao alsa:device=hdmi /usr/share/sounds/ubuntu/stereo/system-ready.ogg
MPlayer 1.1-4.8 (C) 2000-2012 MPlayer Team
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Playing /usr/share/sounds/ubuntu/stereo/system-ready.ogg.
libavformat version 54.20.4 (external)
Mismatching header version 54.20.3
libavformat file format detected.
[lavf] stream 0: audio (vorbis), -aid 0
Load subtitles in /usr/share/sounds/ubuntu/stereo/
Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
libavcodec version 54.35.0 (external)
AUDIO: 44100 Hz, 1 ch, floatle, 80.0 kbit/5.67% (ratio: 10000->176400)
Selected audio codec: [ffvorbis] afm: ffmpeg (FFmpeg Vorbis)
[AO_ALSA] alsa-lib: confmisc.c:768:(parse_card) cannot find card '1'
[AO_ALSA] alsa-lib: conf.c:4248:(_snd_config_evaluate) function snd_func_card_driver returned error: No such file or directory
[AO_ALSA] alsa-lib: confmisc.c:392:(snd_func_concat) error evaluating strings
[AO_ALSA] alsa-lib: conf.c:4248:(_snd_config_evaluate) function snd_func_concat returned error: No such file or directory
[AO_ALSA] alsa-lib: confmisc.c:1251:(snd_func_refer) error evaluating name
[AO_ALSA] alsa-lib: conf.c:4248:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
[AO_ALSA] alsa-lib: conf.c:4727:(snd_config_expand) Evaluate error: No such file or directory
[AO_ALSA] alsa-lib: pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM hdmi
[AO_ALSA] Playback open error: No such file or directory
Failed to initialize audio driver 'alsa:device=hdmi'
Could not open/initialize audio device -> no sound.
Audio: no sound
Video: no video
Exiting... (End of file)
mplayer -ao alsa:device=hw=0.3 /usr/share/sounds/ubuntu/stereo/system-ready.ogg
[AO_ALSA] Format floatle is not supported by hardware, trying default.
AO: [alsa] 44100Hz 2ch s16le (2 bytes per sample)
Video: no video
Starting playback...
A:   0.4 (00.4) of 0.8 (00.7)  0.1%
Thank you for your time and help :)
UPDATE: I have now added a Creative Soundblaster play 2 USB sound card and disabled the onboard from the BIOS. On my Ubuntu desktop it works right away so the hardware works for sure. On the server its not doing anything. Still only a dummy output in the sound settings (pulse).
reinstalled/purged/etc but to no avail.
alsamixer is not opening at all any more, proc/asound doesn't exist
sudo aplay -l
aplay: device_list:268: no soundcards found...
lspci -v | grep -A7 -i "audio"
00:03.0 Audio device: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller (rev 06)
    Subsystem: ASUSTeK Computer Inc. Device 8534
    Flags: bus master, fast devsel, latency 0, IRQ 11
    Memory at f7d10000 (64-bit, non-prefetchable) [size=16K]
    Capabilities: <access denied>
00:14.0 USB controller: Intel Corporation Device 8cb1 (prog-if 30 [XHCI])
find /lib/modules/`uname -r` | grep snd
(nothing)
solved by reverting to older kernel.....
