I have tried:
Untrusted Application Launcher
and
Untrusted application launcher?
neither of above applies to this case, as I made a symbolic link:
/usr/share/applications$ ls -la onboard.desktop
-rwxr-xr-x 1 root root 326 Apr  7 12:21 onboard.desktop
~/Desktop$ ls -la
lrwxrwxrwx  1 lj lj   39 Jul 26 22:22 onboard.desktop -> /usr/share/applications/onboard.desktop
unity claims owner is root, and as it may be noted x flag is on.
finally this was working until last update (yesterday)
14.04lts/unity
Lj MT
  • 149
I had the same issue on ubuntu 18.04: .desktop file in /usr/share/applications, owned by root with permissions 644, and a link to it in many users desktop.
If a user double clicks on the link in their Desktop directory, the "Untrusted application" dialog pops up, because (I think) the link is treated as a normal file, which can't be executed in /home or /tmp directories without executable bit set, as explained in: Permission of a .desktop file
To fix this, a chmod +x /usr/share/applications/app.desktop was sufficient.
The file is owned by root on your system,this location is in the root file system /usr/share/applications/onboard.desktop. Try this
1 make a new folder in your home folder and put your .desktop in this new folder
2 open a terminal and type sudo -i and enter your password
3 Type cd then drag and drop the new folder you made on the terminal, this will enter that folder.
4 type chmod +x onboard.desktop
This will change the permissions of the file as root and should allow your user access to the file.
NOTE any file you see with a little padlock icon is owned by another user
Please look here for how to properly make a .desktop LINK
Mark Kirby
  • 18,949
  • 19
  • 79
  • 116
