I want to sync subscribed feeds, e.g. rss and atom feeds, in Thunderbird between computers.
Here is an example case to describe what I'm asking for. Say that I have the following setup:
  1. A laptop on which I've in Thunderbird subscribed to certain feeds.
  2. A desktop on which I've in Thunderbird subscribed to certain feeds.
What I want is that the subscribed feeds in Thunderbird are the same on the laptop and the desktop. For example if I add a subscription on the laptop it will also be added to the desktop and if I remove a subscription from the desktop it will also be removed from the laptop. Also, I want posts that are read on one computer to be marked as read on the other computer.
If it matters my particular setup is such that I can connect to my desktop from anywhere via an URL but my laptop is harder to access since it might be behind NAT and such. Also, I'm already syncing other things with Unison.
N.N.
  • 18,589
You can use dropbox and symlinks from your ~/Dropbox folder to your ~/.thunderbird folder to sync the relevant files.
For example: On the first system:
  • mv ~/.thunderbird ~/Dropbox/thunderbirdsync
  • ln -s ~/Dropbox/thunderbirdsync ~/.thunderbird
On the second one:
  • rm -i -r ~/.thunderbird (I believe you are using the same mail accounts on each system?)
NB: You can do this from your file manager as well, though it would be more complicated to explain in text.
P.S. if anyone spots any mistakes, edit the answer, or leave a comment.
RolandiXor
  • 51,797
