I've just installed Ubuntu 14.04. Besides of default hard drive, I got also external hard drive on which I would like to install Google Drive. How can I do it?
I've read Is there a Google Drive client available? but I don't know how to change the location (from internal hard drive to external)?
Result of:
sudo blkid; sudo parted -l
please find below. It's in polish ;)
/dev/sda1: UUID="98c61393-a17a-4c01-ab52-49b62a33a3ff" TYPE="ext4"
/dev/sda5: UUID="cefb2e69-872b-4832-9ef5-7576d5082af9" TYPE="swap"
/dev/sdb1: LABEL="DATA" UUID="6A5AA8035AA7CA61" TYPE="ntfs"
Model: ATA PLEXTOR PX-128M6 (scsi)
Dysk /dev/sda: 128GB
Rozmiar sektora (logiczny/fizyczny): 512B/512B Tablica partycji: msdos
Numer  Początek  Koniec  Rozmiar  Typ       System plików   Flaga  1
1049kB    120GB   120GB    primary   ext4            ładowalna  2
120GB     128GB   8479MB   extended  5     120GB     128GB   8479MB
logical   linux-swap(v1)
Model: ASMT 2105 (scsi) Dysk /dev/sdb: 1000GB Rozmiar sektora
1049kB    1000GB  1000GB   primary  ntfs
result of
cat /etc/fstab
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
#<file system> <mount point>   <type>  <options>       <dump>  <pass>
# / was on /dev/sda1 during installation
UUID=98c61393-a17a-4c01-ab52-49b62a33a3ff /               ext4   errors=remount-ro 0       1
# swap was on /dev/sda5 during installation
UUID=cefb2e69-872b-4832-9ef5-7576d5082af9 none            swap    sw   0       0
UUID=6A5AA8035AA7CA61 /home/suzk/Drive ntfs-3g rw,exec,uid=,gid=,umask=0022
UUID=6A5AA8035AA7CA61 /home/suzk/Drive ntfs-3g rw,exec,uid=1000,gid=1000,umask=0022
UUID=6
suz
  • 101
From what I understand, the Grive application uses ~/Google Drive (i.e., something like /home/suz/Drive) as the sync folder. You can mount the external disk at ~/Drive (or some folder within that folder). You will need to edit /etc/fstab for that, and make sure the external disk is connected whenever grive starts up.
You can mount your external drive to ~/Google Drive using the following commands:
mkdir -p ~/Google\ Drive
sudo umount /dev/sdb1
sudo sed -i.bak '/6A5AA8035AA7CA61/d' /etc/fstab
sudo tee -a /etc/fstab <<EOF
UUID=6A5AA8035AA7CA61 $HOME/Google\040Drive ntfs-3g rw,exec,uid=$(id -u),gid=$(id -u),umask=0022
EOF
sudo mount ~/Google\ Drive
This will mount your external disk on ~/Google Drive with correct permissions.
muru
  • 207,228
