I recently tried installing Ubuntu 14.04 on a new Asus VivoPC vm60 and it didn't work. The GRUB loader would abort with the message:
drm_kms_helper: panic occured...
I wasn't able to find any direct help regarding this so I thought I would post my question here.
galoget
  • 3,023
If you want 14.04: BIOS -> WLAN -> Disable. This way you'll be able to boot and install Ubuntu.
After that, make sure to install all the available updates because newer kernels got added support to the wireless chip on board.
You don't need anything else to do: just install updates, and re-enable WLAN in BIOS. It will work.
gerlos
  • 2,904
Lev
I just installed Ubuntu 14.04.1 on an Asus VivoPC VM60 by temporarily disabling the Wireless Network setting in the BIOS. This stops the Grub Loader from aborting during installation. After the installation is complete, go back into the BIOS and turn the Wireless Network setting back ON. The wireless adapter will automatically be recognized and installed during the next boot up.
To enter BIOS, press the F2 or Del keys during power up.
In the BIOS, choose the ADVANCED screen and select Onboard Devices Configuration. Then select WLAN Controller and change the setting from Enable to Disable. To save the changes and exit, press F10.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
I also tried to install Ubuntu on Asus VivoMini VM45, and unfortunately the update to the latest kernel version (now it is 4.15.0-36) does not solve the problem. As I understand, the problem is in the RTL8723BE wifi chip and its driver. A temporary solution,that I found is:
  1. Installing the OS with the Wifi controller disabled in BIOS.
  2. Config GRUB to running OS with the option pci=noaer
  3. Turn WIFI on.
More detail and how to set up a GRUB, on link:
This bug is described here
Installing Ubuntu 12.10 LTS worked! Not sure why 14.04 didn't work... The update manager popped up and asked me if I wanted to upgrade to 14.04; I decided to give it a try to see what happens. The upgrade is really slow (taking 1-2hours), but so far seems to be working... I'll check back in tomorrow after it finishes if it fails...
