How do you get rosegarden to play sound when playing a midi in it? Do I need Jack running?
You do not need to have Jack running in order to playback MIDIs with Rosegarden.
What I now have running is MIDI file playback via Rosegarden and QSynth.
The process as of Ubuntu 17.10 is largely the same as here, but follow these steps:
- install QSynth
apt-get install fluidsynth - install a soundfont library
apt-get install fluid-soundfont-gs - configure QSynth to
Enable MIDI Inputby checking the box inSetup > MIDI - configure QSynth to use
alsaAudio Driver underSetup > Audio - configure QSynth to use the soundfont under
Setup > Soundfonts; point to/usr/share/sounds/sf2/FluidR3_GM.sf2or your soundfont location - allow QSynth to restart when it prompts you
- install Rosegarden
apt-get install rosegarden - with QSynth open, launch Rosegarden
- Tell Rosegarden to play through QSynth
Studio > Manage MIDI Devicesand set theGeneral MIDI Deviceto whatever QSynth broadcasts as its MIDI input option, ie129:0 Synth input portor similar.
- 1,351
The documentation says:
Rosegarden includes synth plugin support for sample-accurate synthesis of MIDI tracks.
And as well as plugins, Rosegarden can communicate with any number of standalone soft synths for Linux using the ALSA sequencer MIDI protocol.
Synth plugins usually are very specialized; if you want to play some random MIDI file, you probably need a general-puporse software synthesizer like Fluidsynth or Timidity.
- 1,795
I adapted the Rosegarden+Qsynth answer to work without having to open 2 different windows, as follows:
- Install
fluidsynthandrosegarden, as well as the corresponding soundfonts viaapt - Add the following function to
~/.bashrcor~/.bash_aliases:
midy() {
if [ -n "$1" ]; then
rosegarden "$1" &
else
rosegarden &
fi
fluidsynth -a alsa -m alsa_seq -o midi.autoconnect=True <PATH_TO_YOUR_SF2_FILE>
- Open a new terminal: type
midyand load a MIDI file, ormidy <PATH_TO_MIDI_FILE>, and hit play:rosegardenshould open, andfluidsynthshould play the file in the background, without the need of a Qsynth window!
Notes:
To test that
fluidsynthis working, you can try the corresponding command (after thefi) separately, by adding the path to the MIDI file at the end. It should play the file.In my case the
.sf2files were installed under/usr/share/sounds/sf2You can find further options by checking
man fluidsynthandfluidsynth -o help
Hope this helps! Cheers
Andres
- 111
- 3
