I have searched for many options on the Internet to install VLC media player on Ubuntu 14.04 (Trusty Tahr), but nothing is working for me.
How can I fix this problem?
Errors:
root@hiteshb-To-be-filled-by-O-E-M:~# apt-get install vlc
Reading package lists... Done
Building dependency tree
The following extra packages will be installed:
  libavcodec54 libavformat54 libchromaprint0 libmp3lame0 libvlc5 libvlccore7
  vlc-data vlc-nox vlc-plugin-notify vlc-plugin-pulse
Suggested packages:
  libchromaprint-tools python-acoustid videolan-doc
Recommended packages:
  libdvdcss2
The following NEW packages will be installed:
  vlc vlc-data vlc-nox vlc-plugin-notify vlc-plugin-pulse
0 upgraded, 11 newly installed, 0 to remove and 0 not upgraded.
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
HDB
  • 223
As of 2015-09-23, the latest VLC version for UbuntuĀ 14.04 (Trusty Tahr) provided by this repository is 2.2.1.
Open a terminal and run (for 14.04):
sudo add-apt-repository ppa:mc3man/trusty-media
sudo apt-get update
sudo apt-get install vlc vlc-plugin-*
For other versions, see here.
Ravan
  • 9,567
To install VLC media player on Ubuntu you can try to open your terminal (Ctrl+Alt+T) and type:
If there are errors, you are welcome to paste the output so people will be able to help you.
You can try to disable IPv6 on your box. Sometimes it can be an issue. To disable IPv6, add the following to /etc/sysctl.conf:
net.ipv6.conf.all.disable_ipv6 = 1
net.ipv6.conf.default.disable_ipv6 = 1
net.ipv6.conf.lo.disable_ipv6 = 1
After that open your terminal (Ctrl+Alt+T) and type:
sudo sysctl -p && sudo apt-get update && sudo apt-get install vlc
try this...
sudo apt-get update
sudo apt-get upgrade
-1
This worked for me in 2015-1-8:
sudo add-apt-repository ppa:djcj/vlc-stable
sudo apt-get update
Eric Carvalho
  • 55,453
shuo
