I have the same problem that the user in "Dummy Output in Ubuntu 14.04".
The difference is that cat /proc/asound/card0/codec* | grep Codec outputs:
cat: /proc/asound/card0/codec*: No existe el archivo o el directorio
(It's in Spanish, it means it cannot find the file or directory)
More info:
$ sudo modprobe snd-hda-intel
modprobe: FATAL: Module snd-hda-intel not found.
$ sudo alsa force-reload
Unloading ALSA sound driver modules: (none loaded).
Loading ALSA sound driver modules: (none to reload).
$ sudo aplay -l
aplay: device_list:268: no soundcards found...
$ lspci | grep -i audio
00:1b.0 Audio device: Intel Corporation 7 Series/C210 Series Chipset Family
    High Definition Audio Controller (rev 04)
$ lspci -v | grep audio
(nothing)
$ locate snd-hda-intel
(nothing)
$ lsmod | grep snd
(nothing)
Braiam
  • 69,112
marlanbar
  • 62
First, we need to know what type of audio hardware (if any) the system detects:
And
:~$ lsmod | grep snd
Please run this command and post the output. Should be something like the following:
:~$ lspci -v | grep audio
00:1f.4 Multimedia audio controller: Intel Corporation 82801BA/BAM AC'97 \
  Audio     Controller (rev 02)
And
snd_intel8x0           38153  0
snd_ac97_codec        130285  1 snd_intel8x0
ac97_bus               12730  1 snd_ac97_codec
snd_pcm               102099  2 snd_ac97_codec,snd_intel8x0
snd_page_alloc         18710  2 snd_intel8x0,snd_pcm
snd_timer              29482  1 snd_pcm
snd                    69238  4 snd_ac97_codec,snd_intel8x0,snd_timer,snd_pcm
soundcore              12680  1 snd
Additional information for troubleshooting
What is the output of the following?
:~$ locate snd-hda-intel
Several users on other posts were able to get this audio chipset working by editing /etc/modprobe.d/alsa-base.conf
nano /etc/modprobe.d/alsa-base.conf
And add the following line:
options snd-hda-intel model=generic
Posts referenced/researched:
Several users on other posts were able to get this audio chipset working by editing /etc/modprobe.d/alsa-base.conf:
This worked for me on a Philips Freevent x55, although I had to use sudo gedit instead of nano.
Jens Erat
  • 5,131
  • 33
  • 37
JT20
  • 39
Alternate method to fix sound (due to misconfigured/unconfigured packages after install/update/upgrade).
  • Fix packages that are not properly configured
:~$sudo dpkg --configure -a, then do a :~$sudo reboot
Post referenced: It's F.O.S.S., Fix No Sound in Ubuntu
