My platform is Ubuntu 12.04.
I have been reading and this text actually follows the flow on the link, Broken package after update: linux-headers, error: BrokenCount >0
I have a broken package after an update. Originally my disk was full but I have since fixed that and I have 4+ gigs free space now.
I then read here that I should run the commands:
sudo apt-get -f install
sudo apt-get install --fix-broken,
I got the following results:
(Reading database ... 897477 files and directories currently installed.)
Unpacking linux-image-3.2.0-67-generic (from .../linux-image-3.2.0-67-generic_3.2.0-67.101_amd64.deb) ...
Done.
dpkg: error processing /var/cache/apt/archives/linux-image-3.2.0-67-generic_3.2.0-67.101_amd64.deb (--unpack):
unable to create `/lib/modules/3.2.0-67-generic/kernel/drivers/usb/gadget/g_dbgp.ko.dpkg-new' (while processing `./lib/modules/3.2.0-67-generic/kernel/drivers/usb/gadget/g_dbgp.ko'): No space left on device
No apport report written because the error message indicates a disk full error
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Examining /etc/kernel/postrm.d .
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 3.2.0-67-generic /boot/vmlinuz-3.2.0-67-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 3.2.0-67-generic /boot/vmlinuz-3.2.0-67-generic
Unpacking linux-headers-3.2.0-67 (from .../linux-headers-3.2.0-67_3.2.0-67.101_all.deb) ...
dpkg: error processing /var/cache/apt/archives/linux-headers-3.2.0-67_3.2.0-67.101_all.deb (--unpack):
error creating directory `./usr/src/linux-headers-3.2.0-67/crypto/async_tx': No space left on device
Unpacking linux-headers-3.2.0-67-generic (from .../linux-headers-3.2.0-67-generic_3.2.0-67.101_amd64.deb) ...
dpkg: error processing /var/cache/apt/archives/linux-headers-3.2.0-67-generic_3.2.0-67.101_amd64.deb (--unpack):
unable to create `/usr/src/linux-headers-3.2.0-67-generic/include/config/mtd/scb2/flash.h.dpkg-new' (while processing `./usr/src/linux-headers-3.2.0-67-generic/include/config/mtd/scb2/flash.h'): No space left on device
I then read some more and ran this command,
df -i
And got these results.
Filesystem Inodes IUsed IFree IUse% Mounted on
/dev/sda3 915712 914583 1129 100% /
udev 253906 560 253346 1% /dev
tmpfs 256105 502 255603 1% /run
none 256105 3 256102 1% /run/lock
none 256105 5 256100 1% /run/shm
/dev/sda6 1220608 30875 1189733 3% /home
/dev/sdb1 821888880 141598 821747282 1% /media/Seagate Backup Plus Drive
So reading on I ran this command,
sudo du -h /* | grep '[0-9]M'
and I too got a huge list, 10 text pages to be exact.
But at that point I get lost. I haven't any idea which file is too big or which is not. Some of the files are as big as
- 354M /var/lib
- 636M /var
- 130M /var/cache/apt
- 260M /var/cache
But nowhere in the list is the word, “trash,” and when I run the command,
sudo rm -r /root/.local/share/Trash/files/
It tells me file trash not found. I think I understand that what I have to do is figure out how to get the line that reads
to read something less than 100% so that I have room to fix the broken package but I am at a loss how to do that. And I am apprehensive to just start erasing things Willy-nilly.
I am willing to read so if there is a link some place that talks all about this just point me and I will go digest as best as I am able.
Thanks to anyone for the help.
$ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/sda3 14G 12G 2.1G 85% /
udev 992M 4.0K 992M 1% /dev
tmpfs 201M 1.1M 200M 1% /run
none 5.0M 0 5.0M 0% /run/lock
none 1001M 140K 1001M 1% /run/shm
/dev/sda6 19G 14G 4.0G 78% /home
/dev/sdb1 932G 148G 784G 16% /media/Seagate Backup Plus Drive
/dev/sda7 104G 188M 99G 1% /media/cd3f76e1-724f-4b8f-b29c-cc901b071fdb
/dev/sda2 94G 84G 9.8G 90% /media/069CBC4E9CBC3A4F
$ df -h /boot
