Im a real noob with computers and installed accidentally Xmonad, without knowning that it was code-based. How can i switch back to unity?
disk
Two imperfect ways to do this:
(Assuming Unity is still installed)
  • ctrl + alt + t to open up a terminal, and type:
    unity --replace
or
Anon
  • 12,339
Use CTRL + ALT + F1 like you did before and login with your username and password.
Then type this:
sudo apt-get purge xmonad && sudo apt-get install --reinstall ubuntu-desktop
When that's said and done with, you can start a regular xsession with this command:
sudo service lightdm start
or
sudo service lightdm restart
To bypass the login screen and go directly into your default desktop type:
startx
To see if there are any other related packages still installed you can type this command:
dpkg -l | grep xmonad
No output = no packages are installed.
mchid
  • 44,904
  • 102
  • 162
