In Unity, pressing Super + 1 to 9 launches or switches focus to an application. Can I assign a keyboard shortcut with a similar property in Lubuntu (i.e. in LXDE)?
More precisely, can I set up a shortcut such that if the application is already opened then focus will switch to it and the workspace will change accordingly (like in Unity)? So far I have only managed to assign a shortcut that launches (a new instance of) the application.
Glutanimate
  • 21,763
DustByte
  • 651
Openbox (LXDE's window manager) doesn't have an inbuilt functionality for this, but with a little help from xdotool we can write a script that can replicate and even enhance Unity's behaviour.
First, make sure you have xdotool installed:
sudo apt-get install xdotool
Save the following script as focus_or_launch and make it executable:
 #!/bin/bash
# NAME:         focus_or_launch
# VERSION:      0.4
# AUTHOR:       (c) 2014 Glutanimate <https://github.com/Glutanimate/>
# DESCRIPTION:  Focus existing app window or launch application if no
#               window found
#               Simplified version of a script by Henning Bekel
#               (https://bbs.archlinux.org/viewtopic.php?pid=625009#p625009)
# DEPENDENCIES: xdotool
# LICENSE:      GNU GPLv3 (http://www.gnu.de/documents/gpl-3.0.en.html)
# NOTICE:       THERE IS NO WARRANTY FOR THE PROGRAM, TO THE EXTENT PERMITTED BY APPLICABLE LAW.
#               EXCEPT WHEN OTHERWISE STATED IN WRITING THE COPYRIGHT HOLDERS AND/OR OTHER PARTIES
#               PROVIDE THE PROGRAM “AS IS” WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESSED OR
#               IMPLIED, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY
#               AND FITNESS FOR A PARTICULAR PURPOSE. THE ENTIRE RISK AS TO THE QUALITY AND
#               PERFORMANCE OF THE PROGRAM IS WITH YOU. SHOULD THE PROGRAM PROVE DEFECTIVE,
#               YOU ASSUME THE COST OF ALL NECESSARY SERVICING, REPAIR OR CORRECTION.
#               IN NO EVENT UNLESS REQUIRED BY APPLICABLE LAW OR AGREED TO IN WRITING WILL ANY
#               COPYRIGHT HOLDER, OR ANY OTHER PARTY WHO MODIFIES AND/OR CONVEYS THE PROGRAM AS
#               PERMITTED ABOVE, BE LIABLE TO YOU FOR DAMAGES, INCLUDING ANY GENERAL, SPECIAL,
#               INCIDENTAL OR CONSEQUENTIAL DAMAGES ARISING OUT OF THE USE OR INABILITY TO USE
#               THE PROGRAM (INCLUDING BUT NOT LIMITED TO LOSS OF DATA OR DATA BEING RENDERED
#               INACCURATE OR LOSSES SUSTAINED BY YOU OR THIRD PARTIES OR A FAILURE OF THE
#               PROGRAM TO OPERATE WITH ANY OTHER PROGRAMS), EVEN IF SUCH HOLDER OR OTHER
#               PARTY HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES.
# USAGE:        focus_or_launch <command>
# EXAMPLE:      focus_or_launch google-chrome
############# GLOBVAR/PREP ###############
Executable="$1"
ExecutableBase="$(basename "$Executable")"
Usage="\
Usage: $(basename $0) command
E.g.:  $(basename $0) google-chrome\
############## USGCHECKS #################
if [[ $# -ne 1 || "$1" =~ ^(-h|--help)$ ]]; then
  echo "$Usage"
  exit 1
fi
################ MAIN ####################
MostRecentWID="$(xdotool search --class --name "$ExecutableBase" | tail -1 2> /dev/null)"
if [[ -z "$MostRecentWID" ]]; then
  echo "$ExecutableBase not found. Launching new window."
  "$Executable" > /dev/null 2>&1 &
  disown
else
  echo "Focusing existing instance of $ExecutableBase."
  # use brute-force approach if activating most recent WID doesn't work
  xdotool windowactivate "$MostRecentWID" 2>&1 | grep failed \
  && xdotool search --class --name "$ExecutableBase" windowactivate %@
fi
Here's how the script works: When you run focus_or_launch application xdotool will look for existing instances of the application and focus one of them. If no instance is found the script will launch a new one.
To integrate this script with your desktop session edit your openbox configuration file (e.g. ~/.config/openbox/lxde-rc.xml, ../lubuntu-rc.xml or ../rc.xml) and add a section similar to the following for each application you want to control:
<keybind key="W-g">
  <action name="Execute">
    <command>focus_or_launch gedit</command>
  </action>
</keybind>
Make sure to replace focus_or_launch with the path to the script on your system or, alternatively, copy the script to your $PATH.
If you don't want the script to launch a new app instance, simply remove the following section:
disown
P.S.: This script should work on all xdotool-compatible desktop environments (e.g. Unity, GNOME, XFCE...)
Glutanimate
  • 21,763
