I want to add a new Hotkey: When I press F1 it will do the same as Shift+F1 does. I have added a new Custom Shortcut (System -> Keyboard) but I don't know the command to run like we press F1. I appreciate your help.
If you want to add a new Hotkey, for example when you press Shift+F1 call F1 commands, you will need an extra softwae as xbindkeys: xdotool or xte. I follow by using xte.
1. Install xbindkeys:
sudo apt-get install xbindkeys
2. Then install xte:
sudo apt-get install xautomation
The syntax for xte is like this: xte 'command key/mousebutton/xyCoordinates'
for examples:
- To call a single key press:
xte 'key keyName' - To call a key combination:
xte 'keydown keyName' 'keydown secondKeyName' 'keyup keyName' 'keyup secondKeyName - And more! Read
man xte
3. Find the name of a key: xbindkeys allows us to use the -k handle to find the name of a key or key combination.
Run xbindkeys -k and press a key or key combination.
If you pressing Shif+F1 your output will look something similar to this:
"(Scheme function)"
m:0x11 + c:67
Shift+Mod2 + F1
The basic syntax of xbindkeysrc commands is like this:
"Command to run (in quotes)"
key to associate with command (no quotes)
so as you can see at above.
4. Create a file named .xbindkeysrc in your home directory:
touch $HOME/.xbindkeysrc
5. Now open .xbindkeysrc file.
gedit .xbindkeysrc
6. Bind key/key combination to another key/key combination:
So according to first example of xte syntax in step 2, we have this:
xte 'key keyName'
Ok, now combine this command with output of pressing Shif+F1 in step 3 and put in or type into .xbindkeysrc file that we opened in step 5. like this:
"xte 'key F1'"
Shift+Mod2 + F1
7. Save it and exit. Now you might notice your command doesn't work yet, that's because xbindkeys isn't running. To start it just run xbindkeys from a terminal. Your Shif+F1 should now start your F1 command!
According to this Q/A by Seth
When you press the F1 key it opens the system documentation browser (yelp).
You can for instance, access the Nautilus help with:
yelp help:ubuntu-help/files
From yelp man pages:
NAME
yelp — browse system documentation
USAGE
yelp [file]
The GNOME Help Browser includes detailed documentation for the majority
of applications, utilities and other components, such as the panel or
the Nautilus file manager.
Yelp can display some HTML and XML files when passed on the command-
line, but it's primarily called from applications.
You can also start Yelp by choosing Desktop->Help. This will show the
top-level help system page, listing all GNOME documents conveniently
organized by topic.
OPTIONS
This program accepts all the standard GNOME and GTK+ options, which
follow the usual GNU command line syntax, with long options starting
with two dashes (`-'). To get more information about these options
launch Yelp with the `--help' argument.
To know which command(s) are executed by shortcut keys, open a Terminal and look at the result of the ps -aef command, one of the last process is your command:
root 9013 2 0 21:18 ? 00:00:00 [kworker/u16:0]
sylvain 9036 2003 19 21:20 ? 00:00:00 yelp help:gnome-terminal
sylvain 9054 8851 0 21:21 pts/14 00:00:00 ps -aef
- 63,229
