This problem is really strange, I have tried many ways to solve but nothing worked. My last output was:
    Reading package lists... Done
    Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
2 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LANG = "pl_PL.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_MESSAGES to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
Setting up mysql-server-5.5 (5.5.38-0ubuntu0.14.04.1) ...
/var/lib/dpkg/info/mysql-server-5.5.postinst: line 146: logger: command not found
ATTENTION: An error has occured. More info is in the syslog!
/var/lib/dpkg/info/mysql-server-5.5.postinst: line 236: logger: command not found
dpkg: error processing package mysql-server-5.5 (--configure):
subprocess installed post-installation script returned error exit status 127
dpkg: dependency problems prevent configuration of mysql-server:
mysql-server depends on mysql-server-5.5; however:
Package mysql-server-5.5 is not configured yet.
dpkg: error processing package mysql-server (--configure):
dependency problems - leaving unconfigured
mysql-server-5.5
mysql-server
I really don't know how to fix that, guys please help me :)
kevlarjacket
  • 195
  • 15
Had the same issue with mysql-server-5.6 and this solution hs helped me:
launchpad: Bug #392051: [Karmic] logger command not found
Basically, the program logger got messed up;
It can be recreated by reinstalling the package bsdutils:
apt-get --reinstall install bsdutils
or
aptitude reinstall bsdutils
Volker Siegel
  • 13,295
abudaan
  • 251
Your "locales" have not been generated yet, or not properly.
Try this:
sudo locale-gen en_US en_US.UTF-8 pl_PL pl_PL.UTF-8
sudo dpkg-reconfigure locales
Then try again to install MySQL.
Jos
  • 30,529
  • 89
  • 96
This is the original answer referred from this block:
https://smyl.es/how-to-fix-ubuntudebian-apt-get-404-not-found-package-repository-errors-saucy-raring-quantal-oneiric-natty/
Update Locales:
sudo locale-gen fi_FI.UTF-8
apt-get update
Run this command below
On your server and it will replace all of the archive.ubuntu.com and security.ubuntu.com package repository URLs with old-releases.ubuntu.com
sudo sed -i -e 's/us.old-releases.ubuntu.com\|security.ubuntu.com/old-releases.ubuntu.com/g'/etc/apt/sources.list
sudo sed -i -e 's/archive.ubuntu.com\|security.ubuntu.com/old-releases.ubuntu.com/g'/etc/apt/sources.list
apt-get update
Tim
  • 33,500
