I am having a error whilst installing MySQL 5.6 from downloaded deb and from apt:
nginx@LBNginx:/tmp$ sudo dpkg -i mysql-server-5.6_5.6.27-0ubuntu0.14.04.1_amd64.deb
(Reading database ... 121037 files and directories currently installed.)
Preparing to unpack mysql-server-5.6_5.6.27-0ubuntu0.14.04.1_amd64.deb ...
Unpacking mysql-server-5.6 (5.6.27-0ubuntu0.14.04.1) over (5.6.27-0ubuntu0.14.04.1) ...
Setting up mysql-server-5.6 (5.6.27-0ubuntu0.14.04.1) ...
2015-10-27 19:31:17 0 [Warning] TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_defaults_for_timestamp server option (see documentation for more details).
2015-10-27 19:31:17 0 [Note] /usr/sbin/mysqld (mysqld 5.6.27-0ubuntu0.14.04.1) starting as process 7666 ...
2015-10-27 19:31:17 7666 [Note] Plugin 'FEDERATED' is disabled.
2015-10-27 19:31:17 7666 [Note] InnoDB: Using atomics to ref count buffer pool pages
2015-10-27 19:31:17 7666 [Note] InnoDB: The InnoDB memory heap is disabled
2015-10-27 19:31:17 7666 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
2015-10-27 19:31:17 7666 [Note] InnoDB: Memory barrier is not used
2015-10-27 19:31:17 7666 [Note] InnoDB: Compressed tables use zlib 1.2.8
2015-10-27 19:31:17 7666 [Note] InnoDB: Using Linux native AIO
2015-10-27 19:31:17 7666 [Note] InnoDB: Not using CPU crc32 instructions
2015-10-27 19:31:17 7666 [Note] InnoDB: Initializing buffer pool, size = 128.0M
2015-10-27 19:31:17 7666 [Note] InnoDB: Completed initialization of buffer pool
2015-10-27 19:31:17 7666 [Note] InnoDB: Highest supported file format is Barracuda.
2015-10-27 19:31:17 7666 [Note] InnoDB: 128 rollback segment(s) are active.
2015-10-27 19:31:17 7666 [Note] InnoDB: Waiting for purge to start
2015-10-27 19:31:17 7666 [Note] InnoDB: 5.6.27 started; log sequence number 1626007
2015-10-27 19:31:17 7666 [Note] Binlog end
2015-10-27 19:31:17 7666 [Note] InnoDB: FTS optimize thread exiting.
2015-10-27 19:31:17 7666 [Note] InnoDB: Starting shutdown...
2015-10-27 19:31:19 7666 [Note] InnoDB: Shutdown completed; log sequence number 1626017
start: Job failed to start
invoke-rc.d: initscript mysql, action "start" failed.
dpkg: error processing package mysql-server-5.6 (--install):
 subprocess installed post-installation script returned error exit status 1
Processing triggers for man-db (2.6.7.1-1ubuntu1) ...
Processing triggers for ureadahead (0.100.0-16) ...
 mysql-server-5.6
I have completely removed MySQL from the system and tried again but still no avail.
Note: I am running Ubuntu Server Trusty
meun5
  • 163
first remove mysql-server completely using commands:
sudo apt-get remove --purge mysql-server mysql-client mysql-common
sudo apt-get autoremove
sudo apt-get autoclean
then try to install it again.
sudo apt-get install mysql-server
if you installing with dpkg command and if it show any dependency on other package then run command :
sudo apt-get install -f
then try again to install
EDIT: Here is bug with mysql-server-5.6 so try lower version of mysql-server. if you want to install mysql-server-5.6 then you can use this PPA.
create any file under /etc/apt/sources.list.d/
sudo vi /etc/apt/sources.list.d/mysql.list
and paste below lines and save it.
deb http://ppa.launchpad.net/ondrej/mysql-5.6/ubuntu trusty main
deb-src http://ppa.launchpad.net/ondrej/mysql-5.6/ubuntu trusty main
and update it
sudo apt-get update
then install it using command
sudo apt-get install mysql-server-5.6
it is tested on Ubuntu 14.04 . Here is PPA available for Ubuntu Version 12.04 ,14.04 ,14.10, 15.04 and 15.10.
pl_rock
  • 11,715
I got same issue when I followed following tutorial to install mysql 5.6 on ubuntu 14.
I had installed Ubuntu using vagrant. I had assigned only 512 MB to the virtual machine.
To fix it I did following things.
1) Increased the virtual machine Memory to 1024MB
config.vm.provider "virtualbox" do |vb| # # Display the VirtualBox GUI when booting the machine # vb.gui = true # # # Customize the amount of memory on the VM: vb.memory = "1024" end
2) Run vagrant reload command
3) Then uninstalled the MySql
sudo apt-get remove mysql-server mysql-client
sudo apt-get install mysql-server-5.6 mysql-client-5.6
4) Then again installed MySql and it worked for me.
Mukesh
  • 113
Seems like a problem with mysql-common, you need to use mysql-common 5.5.46-0ubuntu0.14.04.2 for mysql-server-5.6_5.6.27
After you executed
try with this https://gist.github.com/dranes/e65bbaa8c7800fd12575
Dranes
Atlast this worked for me
sudo apt-get install -f mysql-server
I added -f in the command, after removing mysql completely. That did the trick!
