I am trying to install ubuntu 14.2.16 on VirtualBox. It has installed correctly, but I was having a problem related to window size. It is not possible for me to switch ubuntu in full screen mode. I got some solution for that i.e. installing Guest Additions. But afterwords I got error: unable to mount C:program files/oracle/VirtualBox/GuestAssitions.iso For that i got one solution.(Unable to mount the CD/DVD image on the machine Sandbox) I followed all steps given by but as it says about VBoxLinuxAdditions.run file, it should be executable. But file I am having in my host PC is not executable. I even checked settings in file property, its type is program still not executable, its opening in text editor.
What should I do now? Even if anybody could suggest me different solution for switching it in full screen it would be really helpful.
Installing Virtualbox guest addition from terminal did the trick for me.
sudo apt-get install virtualbox-guest-dkms virtualbox-guest-utils virtualbox-guest-x11
sagar
  • 141
sudo apt-get install virtualbox-guest-x11
As of 'unable to mount' problem, you can insert C:\Program Files\Oracle\VirtualBox\VBoxGuestAdditions.iso file into virtual CD/DVD manually, and them mount /dev/cdrom device to a folder of your choice (mount /dev/cdrom /mnt/mycdfolder).
I had the same issue running a Virtualbox on a Macbook Air. Here is what I did to remedy the problem.
Update your system to the latest packages:
apt-get update -y
apt-get upgrade -y
apt-get dist-upgrade -y
Then reboot
Then install all the dependencies by running the following command:
apt-get install linux-headers-$(uname -r)
Then reboot again.
Load the VirtualBox guest additions CD. Create a folder and copy the files from the CD to your Hard drive. I copied everything even though I probably didn't have to.
Then chmod 755 VBoxLinuxAdditions.run ./VBoxLinuxAdditions.run reboot and it should work.
This worked for me
Phil UK
  • 1,397
Ensure that you've installed VirtualBox Guest Additions. In the window of the guest VM, check the bottom right for a line of icons. The icon second from the right, looks like a blue egg at an angle and a green arrow to the right. If you hover your mouse over that, the tooltip will tell you if Guest Additions is installed.
If Guest Additions is not installed, then you must install it if you want do things like change the video resolution. See here for more background. Remember to use sudo before any command when installing/running, which the link I gave does not use in all places.
karel
  • 122,292
  • 133
  • 301
  • 332
Bernmeister
  • 1,149
