When I attempt to install pipelight, an error message displays on the terminal:
Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation:
The following packages have unmet dependencies: pipelight-multi : Depends: ttf-mscorefonts-installer but it is not installable E: Unable to correct problems, you have held broken packages.
I follow these directions:
sudo add-apt-repository ppa:pipelight/stable
sudo apt-get update
sudo apt-get install --install-recommends pipelight-multi
sudo pipelight-plugin --update
When I attempt to enter the third command, it then displays that error above. I've been using Ubuntu for a few days now so, I'm still getting acclimated with everything. Any suggestions or tips would be very helpful.
Thank you.
ElefantPhace
  • 3,281
Sounds like you don't have the multiverse repository enabled, which is where ttf-mscorefonts-installer lives.
Follow this question How do I enable the "multiverse" repository? on how to enable it.
After that try again and proceed with enabling pipelight just to make sure
 sudo pipelight-plugin --enable silverlight
Follow through with that and you should be good to watch Netflix in your desired browser.
Or you can install the Netflix app provided in the ppa
 sudo apt-get install netflix-desktop
ElefantPhace
  • 3,281
