22
I installed the NodeJS in Ubuntu 14.04 by nvm by following this site Installing NodeJS Though I had the following problem as
nvm ls
    sbin
mkdir: cannot create directory ‘/usr/sbin/alias’: Permission denied
Then I found to resolve this as (from NVM solution)
$ export NVM_DIR=~/.nvm
$ echo $NVM_DIR
/home/roy/.nvm
Then It works fine.
Now the problem, I face is that if I restart or even open a new console, I can't find the node again.
roy@Croy:~$ node -version
The program 'node' can be found in the following packages:
 * node
 * nodejs-legacy
Try: sudo apt-get install <selected package>
I have to follow those steps,
I do nvm install 0.11.13 then it shows
v0.11.13 is already installed.
Now using node v0.11.13
Here is my Stackoverflow question - the following answer is not working.
How to come out from here ?
lara
  • 397
7 Answers7
39
As seen here
  1. Run command:
    which node
    and in my case it displayed /usr/sbin/node.
  2. If it says command not found, skip to 3. Remove it by
    sudo rm /usr/sbin/node
  3. Run command:
    which nodejs
    In my case it displayed /usr/bin/nodejs
  4. Make a link
    sudo ln -s /usr/bin/nodejs /usr/bin/node
    OR
    sudo ln -s /usr/bin/nodejs /usr/sbin/node
Basit
  • 636
Run command:
nodejs -v
For more information: See here.
d a i s y
  • 5,551
Rohit
  • 161
As seen here
Because of a conflict with another package, the executable from the Ubuntu repositories is called nodejs instead of node. Keep this in mind as you are running software.
user@xxx:~ $ node --version
* node
* nodejs-legacy
Ask your administrator to install one of them
user@xxx:~ $ nodejs --version
v0.10.25
niksmac
  • 319
Node has a different name in the current version, mine is v0.10.25.
The current node is just nodejs.
To use the old commands you have to create a symbolic link like this.
and that's it.
Run: node --version
d a i s y
  • 5,551
This is an old post. But I stumbled upon this when I faced the same problem with NPM on WSL2.
I had to create a bash alias to point to the npm that I installed on ubuntu wsl.
alias npm=/usr/bin/npm
The following line adds node to your $PATH:
nvm alias default 5.1
Use your installed node version.
Jens Erat
  • 5,131
  • 33
  • 37
Wes Grant
  • 101
How about using the official instructions from the nodejs site:
For v6:
curl -sL https://deb.nodesource.com/setup_6.x | sudo -E bash -
sudo apt-get install -y nodejs
For v4:
curl -sL https://deb.nodesource.com/setup_4.x | sudo -E bash -
I've tested these from Windows bash (via subsystem for Linux - 14.04) and it had the correct node alias. Running sudo apt-get install -y nodejs without first running the setup script will result in you getting node 0.10.
