12
Please excuse a simple question from a new Linux user. Running Ubuntu 12.04 on a Dell Pentium(R) Dual-Core CPU E5800 @ 3.20GHz × 2.
I installed Dropbox OK with the command:
   cd ~ && wget -O - "https://www.dropbox.com/download?plat=lnx.x86" | tar xzf -
as suggested by the Dropbox web site, which worked fine.
Then the Dropbox daemon was run with the command:
  ~/.dropbox-dist/dropboxd
Again this worked well, Dropbox runs in the background giving easy access to my cloud data.
The Problem
How can I automatically run the dropbox daemon when the session is restarted? Current workaround is to open a terminal and enter the command:
Many thanks
Charo
  • 3,681
ArnieRead
  • 123
I had exactly the same problem and solve it by installing dropbox following these instructions, but substituting nautilus-dropbox by dropbox. That is, I installed dropbox by executing these commands:
sudo apt-key adv --keyserver pgp.mit.edu --recv-keys 5044912E
sudo add-apt-repository "deb http://linux.dropbox.com/ubuntu $(lsb_release -sc) main"
sudo apt-get update
sudo apt-get install dropbox
Charo
  • 3,681
I installed dropbox from the app provided in the Ubuntu Software Centre and works well placing an icon in the top bar of the screen.
graham
  • 13,061
