I have just installed Ubuntu for the second time (separate downloads) onto my nexus 7. Both the times I could not use apt-get upgrade and thus could not install any applications.
Upon the second installation I turned the terminal mode on while setup was happening and noticed that Glibc had not set up properly for some reason both the times (could this be the problem??).
i have tried all the possible things i could find off other questions. some other things i can think would be important are-
  1. during both the downloads the internet connection was lost in the middle and then the download was recovered
  2. i have just attached a new switch into my connection, this has been giving me some DSL problems on my PC but not on WIFI so i dont think this is the cause
  3. i can browse webpages and do virtaully anthing related to the internet on ubuntu but when i try to send an error report or a bug report the the update fails due to no internet connectivity! also when i try to select the best server it gives the same error
  4. ping to 8.8.8.8 gives back a 0% loss
  5. for some reason when i try to select my mirror and chose the regional one (in.ubuntu.archive.com/ubuntu) it selects that mirror but upon reboot resets to the main one. this happens even if i change it in the sources.list
  6. upon installation of the latest 13.04 on my nexus 7, i am asked to upgrade to the more stable 13.10 but i am not able to do this in termianl since it says i have no internet connectivity and when i do it through the update manager, the confirmation window is too big for my screen and i cannot select accept so i am still using the 13.04
  7. apart from the Glibc error displayed on setup i do not beleive there was any other error during installation. i used the Multirom instructions step by step.
  8. the error messages vary everytime from, something wicked has happened to some files failed to install and sometimes both
i have been trying to test this on my old nexus 7 as a test before putting it on my new one, but dont think that i will unless this problem is solved. any help is appreaciated! :)
please tell me if you want to see my sources.list, resolv.conf or installation logs
I have removed http:// so it doesn't show links
root@pranay-finaltest:/home/pranay# apt-get update
Ign archive.ubuntu.com raring Release.gpg
Err archive.ubuntu.com raring/main Sources
  404  Not Found [IP: 91.189.92.200 80]
Err archive.ubuntu.com raring/restricted Sources
Err archive.ubuntu.com raring/universe Sources
Err archive.ubuntu.com raring/multiverse Sources
Err archive.ubuntu.com raring/main armhf Packages
Err archive.ubuntu.com raring/restricted armhf Packages
Err archive.ubuntu.com raring/universe armhf Packages
Err archive.ubuntu.com raring/multiverse armhf Packages
Ign archive.ubuntu.com raring/main Translation-en_IN
Ign archive.ubuntu.com raring/multiverse Translation-en_IN
Ign archive.ubuntu.com raring/restricted Translation-en_IN
Ign archive.ubuntu.com raring/universe Translation-en_IN
W: Failed to fetch
archive.ubuntu.com/ubuntu/dists/raring/main/source/Sources  404  Not
W: Failed to fetch
archive.ubuntu.com/ubuntu/dists/raring/restricted/source/Sources
W: Failed to fetch
archive.ubuntu.com/ubuntu/dists/raring/universe/source/Sources  404
W: Failed to fetch
archive.ubuntu.com/ubuntu/dists/raring/multiverse/source/Sources
W: Failed to fetch
archive.ubuntu.com/ubuntu/dists/raring/main/binary-armhf/Packages
W: Failed to fetch
archive.ubuntu.com/ubuntu/dists/raring/restricted/binary-armhf/Packages
W: Failed to fetch
archive.ubuntu.com/ubuntu/dists/raring/universe/binary-armhf/Packages
W: Failed to fetch
archive.ubuntu.com/ubuntu/dists/raring/multiverse/binary-armhf/Packages
E: Some index files failed to download. They have been ignored, or old ones
used instead.
root@pranay-finaltest:/home/pranay# gedit /etc/apt/sources.list
Ign archive.ubuntu.com raring-security Release.gpg
Err ports.ubuntu.com raring-backports Release.gpg
  Something wicked happened resolving 'ports.ubuntu.com:http' (-11 - System
error)
  404  Not Found [IP: 91.189.91.13 80]
Ign ports.ubuntu.com raring-security Release.gpg
Ign ports.ubuntu.com raring-backports Release
Err archive.ubuntu.com raring-security/main Sources
Err archive.ubuntu.com raring-security/restricted Sources
Err archive.ubuntu.com raring-security/universe Sources
Err archive.ubuntu.com raring-security/multiverse Sources
24% [Waiting for headers]^C
Ign archive.ubuntu.com raring-updates Release.gpg
Err ports.ubuntu.com raring-security/main armhf Packages
  404  Not Found [IP: 91.189.88.140 80]
Err ports.ubuntu.com raring-security/restricted armhf Packages
Err ports.ubuntu.com raring-security/universe armhf Packages
Err ports.ubuntu.com raring-security/multiverse armhf Packages
Ign ports.ubuntu.com raring-security/main Translation-en_IN
Ign ports.ubuntu.com raring-security/multiverse Translation-en_IN
Ign ports.ubuntu.com raring-security/restricted Translation-en_IN
Ign ports.ubuntu.com raring-security/universe Translation-en_IN
  404  Not Found [IP: 91.189.92.201 80]
Err archive.ubuntu.com raring-updates/main Sources
Err archive.ubuntu.com raring-updates/restricted Sources
Err archive.ubuntu.com raring-updates/universe Sources
Err archive.ubuntu.com raring-updates/multiverse Sources
Err archive.ubuntu.com raring-updates/main armhf Packages
Err archive.ubuntu.com raring-updates/restricted armhf Packages
Err archive.ubuntu.com raring-updates/universe armhf Packages
Err archive.ubuntu.com raring-updates/multiverse armhf Packages
Ign archive.ubuntu.com raring-updates/main Translation-en_IN
Ign archive.ubuntu.com raring-updates/multiverse Translation-en_IN
Ign archive.ubuntu.com raring-updates/restricted Translation-en_IN
Ign archive.ubuntu.com raring-updates/universe Translation-en_IN
W: Failed to fetch
ports.ubuntu.com/ubuntu-ports/dists/raring-security/main/binary-armhf/Packages
W: Failed to fetch
ports.ubuntu.com/ubuntu-ports/dists/raring-security/restricted/binary-armhf/Packages
W: Failed to fetch
ports.ubuntu.com/ubuntu-ports/dists/raring-security/universe/binary-armhf/Packages
W: Failed to fetch
ports.ubuntu.com/ubuntu-ports/dists/raring-security/multiverse/binary-armhf/Packages
W: Failed to fetch
W: Failed to fetch
W: Failed to fetch
W: Failed to fetch
W: Failed to fetch
W: Failed to fetch
W: Failed to fetch
W: Failed to fetch
W: Failed to fetch
archive.ubuntu.com/ubuntu/dists/raring-updates/main/source/Sources
W: Failed to fetch
archive.ubuntu.com/ubuntu/dists/raring-updates/restricted/source/Sources
W: Failed to fetch
archive.ubuntu.com/ubuntu/dists/raring-updates/universe/source/Sources
W: Failed to fetch
archive.ubuntu.com/ubuntu/dists/raring-updates/multiverse/source/Sources
W: Failed to fetch
archive.ubuntu.com/ubuntu/dists/raring-updates/main/binary-armhf/Packages
W: Failed to fetch
archive.ubuntu.com/ubuntu/dists/raring-updates/restricted/binary-armhf/Packages
W: Failed to fetch
archive.ubuntu.com/ubuntu/dists/raring-updates/universe/binary-armhf/Packages
W: Failed to fetch
archive.ubuntu.com/ubuntu/dists/raring-updates/multiverse/binary-armhf/Packages
W: Failed to fetch
archive.ubuntu.com/ubuntu/dists/raring-security/main/source/Sources
W: Failed to fetch
archive.ubuntu.com/ubuntu/dists/raring-security/restricted/source/Sources
W: Failed to fetch
archive.ubuntu.com/ubuntu/dists/raring-security/universe/source/Sources
W: Failed to fetch
archive.ubuntu.com/ubuntu/dists/raring-security/multiverse/source/Sources
used instead.
david6
  • 14,528
  • 38
  • 46
pranay
  • 54
I tried some of the ip addresses on my browser and sure enough looking at the list I noticed . . . These are all for "updates" and "security" updates which are no longer provided because 13.04 is EOL - LOL.
There are no updates for this version of Ubuntu anymore. You must use a newer version of Ubuntu or remove the update & security URLs from /etc/apt/sources.list which I do not recommend.
http://archive.ubuntu.com/ubuntu/dists/raring = 404 not found
however
http://archive.ubuntu.com/ubuntu/dists/precise = connection
mchid
  • 44,904
  • 102
  • 162
