When I run: apt-get update I receive the following errors:
Err http://us.archive.ubuntu.com trusty/main armhf Packages 404 Not Found [IP: 91.189.91.13 80] Err http://us.archive.ubuntu.com trusty/universe armhf Packages 404 Not Found [IP: 91.189.91.13 80] Err http://us.archive.ubuntu.com trusty-updates/main armhf Packages 404 Not Found [IP: 91.189.91.13 80] Err http://us.archive.ubuntu.com trusty-updates/universe armhf Packages 404 Not Found [IP: 91.189.91.13 80]
Ign http://us.archive.ubuntu.com trusty/main Translation-en_US
Ign http://us.archive.ubuntu.com trusty/universe Translation-en_US
W: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/trusty/main/binary-armhf/Packages 404 Not Found [IP: 91.189.91.13 80]
W: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/trusty/universe/binary-armhf/Packages 404 Not Found [IP: 91.189.91.13 80]
W: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/trusty-updates/main/binary-armhf/Packages 404 Not Found [IP: 91.189.91.13 80]
W: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/trusty-updates/universe/binary-armhf/Packages 404 Not Found [IP: 91.189.91.13 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
I cleared /etc/apt/sources.list and /etc/apt/sources.list.d and reverted to trusty main repos, e.g, the output of cat /etc/apt/sources.list is simply:
###### Ubuntu Main Repos deb http://us.archive.ubuntu.com/ubuntu/ trusty main universe deb-src http://us.archive.ubuntu.com/ubuntu/ trusty main universe
###### Ubuntu Update Repos deb http://us.archive.ubuntu.com/ubuntu/ trusty-updates main universe deb-src http://us.archive.ubuntu.com/ubuntu/ trusty-updates main universe
What triggers the package manager to look for the binary-armhf directory and how can I stop these errors when updating my packages?
Why is my distro searching for the binary-armhf directory? I'm have an intel i7 and don't believe it uses the arm instruction set, doesn't it have its own x86_64 (I could be wrong, I don't know much about cpu architecture)?
In case it is helpful, the output of cat /proc/cpuinfo for on of my cores is:
processor : 0 vendor_id : GenuineIntel cpu family : 6 model : 44 model name : Intel(R) Core(TM) i7 CPU X 990 @ 3.47GHz stepping : 2 microcode : 0x13 cpu MHz : 1600.000 cache size : 12288 KB physical id : 0 siblings : 12 core id : 0 cpu cores : 6 apicid : 0 initial apicid : 0 fpu : yes fpu_exception : yes cpuid level : 11 wp : yes flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm pcid sse4_1 sse4_2 popcnt aes lahf_lm ida arat epb dtherm tpr_shadow vnmi flexpriority ept vpid bogomips : 6941.82 clflush size : 64 cache_alignment : 64 address sizes : 36 bits physical, 48 bits virtual power management:
Thanks for any direction, I've been struggling with this for a while.
spk593
  • 81
It is likely that you have installed (for example) armhf cross tools (compiler, linker, etc.) that add armhf as foreign architecture. You can verify this by running:
dpkg --print-foreign-architectures
You can remove the foreign architecture by running:
sudo dpkg --force-architecture --remove-architecture armhf
For me, the package adding armhf as foreign architecure was cuda-cross-armhf-6-5.
CliffordVienna
  • 171
I finally found the answer!
apt-get update using binary-x64 instead of binary-amd64 and failing
I am still unclear as to how and why the foreign architectures are populated for the package manager but removing the armhf entry stops the search for the non-existent directory in the trusty repo.
spk593
  • 81
