327
I've downloaded mongodb-linux-x86_64-2.6.3.tgz file using windows 7 and kept it on D:\Amra\Software\Developing Soft location.
When I right click this .tgz file using Ubuntu and see property it shows Location: /media/towhid/Amra/Software/Developing Soft. Now how will I unzip this .tgz file using tar command from terminal?
karel
  • 122,292
  • 133
  • 301
  • 332
Towhid
  • 4,195
To extract a .tgz file with tar you need to use,
tar -xvzf /path/to/yourfile.tgz
where,
  • x for extract
  • v for verbose
  • z for gnuzip
  • f for file, should come at last just before file name.
You can use the following command in a terminal to unzip the file in your case,
tar -xvzf /media/towhid/Amra/Software/Developing\ Soft/mongodb-linux-x86_64-2.6.3.tgz
Extract a .tgz file in different directory:
One can use -C option to extract archive contents to a different directory as following,
tar -xvzf /path/to/yourfile.tgz -C /path/where/to/extract/
sourav c.
  • 46,120
34
Let's end the decades of hardly-memorable one-letter tar options. Use this to extract your .tgz file:
tar --extract --file /path/to/file.tgz
The explanation of used options was purposedly left out.
Jeyekomon
  • 521
Open the terminal and use the cd command to change directories to the directory where the mongodb-linux-x86_64-2.6.3.tgz file is located and the run the following command:
tar xzf mongodb-linux-x86_64-2.6.3.tgz
The above command will extract the contents of the mongodb-linux-x86_64-2.6.3.tgz archive while preserving the archive's hierarchical tree directory structure.
A similar command extracts .tar.xz files. Open the terminal and the run the following command:
tar -xf /path/to/your/file.tar.xz
Explanation:
  • -x extract files from an archive
  • -f use archive file
karel
  • 122,292
  • 133
  • 301
  • 332
