Yes, there are many posts on this site related to this problem especially Dual boot menu with Ubuntu and Windows 8 not showing up and Installing Ubuntu Alongside a Pre-Installed Windows with UEFI . But I'm still unable solve the problem.
I disable fast boot and secure boot in Windows 8.1 and installed Xubuntu Trusty from a Live disk but no GRUB menu whatsoever. The peculiar part is that in the BIOS the "Boot Device Priority" has only two options: "Windows Boot Manager" and "Disabled". I think it's the "Disabled" thing that should be enables but unfortunately I don't know what it is exactly!
I ran Boot Repair from live disk twice with no benefit. The machine is a Samsung ATIV 9. I understand that this question is more about a particular machine's BIOS and Win 8 but I need the answer to be able to use Ubuntu.
Here is the lower part of the output of Boot Repair:
/boot/efi detected in the fstab of sda8: UUID=1C3F-D310     (sda2)
*******lspci -nnk | grep -iA3 vga
00:02.0 VGA compatible controller [0300]: Intel Corporation Haswell-ULT Integrated Graphics Controller [8086:0a16] (rev 09)
Subsystem: Samsung Electronics Co Ltd Device [144d:c109]
Kernel driver in use: i915
00:03.0 Audio device [0403]: Intel Corporation Haswell-ULT HD Audio Controller [8086:0a0c] (rev 09)
grub-install: info: executing modprobe efivars 2>/dev/null.
grub-install: info: Looking for /sys/firmware/efi ...
grub-install: info: ... not found. Looking for /proc/device-tree ...
grub-install: error: /usr/lib/grub/i386-pc/modinfo.sh doesn't exist. Please specify --target or --directory.
GRUB too old for SecureBoot. Please report this message to boot.repair@gmail.com
chroot /mnt/boot-sav/sda8 efibootmgr -v
Fatal: Couldn't open either sysfs or procfs directories for accessing EFI variables.
Try 'modprobe efivars' as root.
chroot /mnt/boot-sav/sda8 uname -r
Kernel: 3.13.0-24-generic
Reinstall the grub-efi of sda8
grub-install : exit code of grub-install :1
Error: no grub*.efi generated. Please report this message to boot.repair@gmail.com
Add /mnt/boot-sav/sda8/boot/efi efi entries in /mnt/boot-sav/sda8/etc/grub.d/25_custom
Adding custom /mnt/boot-sav/sda8/boot/efi/EFI/Microsoft/Boot/bootmgfw.efi
Adding custom /mnt/boot-sav/sda8/boot/efi/EFI/Boot/bootx64.efi
sda2/bootx64.efi already added
sda2/bootmgfw.efi already added
Add /mnt/boot-sav/sda6 efi entries in /mnt/boot-sav/sda8/etc/grub.d/25_custom
Adding custom /mnt/boot-sav/sda6/EFI/Asclepius/bootx64.efi
---- Grub-install verbose
/usr/sbin/grub-install: 1: /usr/sbin/grub-install: cannot create nŵ?ŵ????T?T?@T?@DD?Påtd?ŒÒ?ŒÒLŒÒLl9l9?Qåtd??Råtd?ŵ=?ŵ=nŵ=n?????/lib64/ld-linux-x86-64.so.2???GNU??????GNUm: Directory nonexistent
+ ELF???? @????@@@@@ø?ø????8?8?@8?@?????@@d:?d:? ??ŵ=?ŵ=nŵ=nž{ ? ???
/usr/sbin/grub-install: 1: /usr/sbin/grub-install: ELF????: not found
/usr/sbin/grub-install: 2: /usr/sbin/grub-install: Syntax error: ")" unexpected
/usr/sbin/grub-install : exit code of grub-install :2
---- End of grub-install verbose
chroot /mnt/boot-sav/sda8 update-grub
Generating grub configuration file ...
Found linux image: /boot/vmlinuz-3.13.0-32-generic
Found initrd image: /boot/initrd.img-3.13.0-32-generic
Found linux image: /boot/vmlinuz-3.13.0-24-generic
Found initrd image: /boot/initrd.img-3.13.0-24-generic
Found Windows 8 (loader) on /dev/sda2
Unhide GRUB boot menu in sda8/boot/grub/grub.cfg
An error occurred during the repair.
You can now reboot your computer.
You may want to retry after deactivating the [Backup and rename Windows EFI files] option.
The boot of your PC is in Legacy mode. You may want to retry after changing it to EFI mode.
Reza
  • 1,255
I followed this guide. The point is I had to choose the boot option UEFI after disabling secure boot, and then install Ubuntu. Previously I had set it to CMS.
Reza
  • 1,255
