15
Each time when I want to close terminal there is a popup with question "Close this terminal?" because some process is running in terminal. I don't care about this process. How to prevent terminal from showing this popup?
Wilf
  • 30,732
scdmb
  • 1,217
In 16.04 you'll find that choice in dconf-editor. You can install it, if necessary, with
sudo apt install dconf-editor
Then go to
org -> gnome -> terminal -> legacy
and uncheck confirm-close.
Hinz
  • 592
You will have to install gconf-editor first. Just open the terminal using Ctrl+Alt+T and type the following command:
sudo apt-get install gconf-editor
After that, hit Alt+F2 or open the Dash and type gconf-editor and the configuration editor window will appear. Then you go to AppsGnome-terminalglobal and uncheck the option confirm_window_close.
Source
Fabby
  • 35,017
zian
  • 31
Just press Ctrl + C to cancel any background process that may be running and then you can close the terminal without the popup showing up.
Note:
You can affect your system by closing the terminal with background processes running. A good example is if there is an update or upgrade running, the apt command can get locked up and you may start getting these errors:
E: Could not get lock /var/lib/dpkg/lock - open (11 Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/) is another process using it?
Luckily, they have been solved in this question.
That is just an example of what may happen if you close the terminal when a background process is running. Other things may happen depending on the process itself.
Parto
  • 15,647
