How can I fix this issue:
libgles2-mesa : Depends: libglapi-mesa (= 8.0.4-0ubuntu0.7)
I have already installed libglapi-mesa.
 $ sudo apt-get install libgles2-mesa
Reading package lists... Done
Building dependency tree
The following information may help resolve the situation:
 $ sudo apt-get install libglapi-mesa
libglapi-mesa is already the newest version.
The following packages were automatically installed and are no longer required:
  libts-0.0-0 libmodplug1 libtwolame0 libva-x11-1 libzvbi-common libx264-120 libbluray1 libzvbi0
  libxcb-xv0 libtar0 libdca0 libwebkitgtk-1.0-common libterm-readkey-perl libiso9660-8 libcddb2
  libass4 libdvbpsi7 libdirectfb-1.2-9 libjavascriptcoregtk-1.0-0 libsdl-image1.2 libenca0
  libresid-builder0c2a libupnp3 libaacs0 libmatroska5 libxcb-keysyms1 liba52-0.7.4 libdvdnav4
  libdvdread4 libxcb-composite0 libkate1 libjpeg62 libsidplay2 gir1.2-rsvg-2.0 tsconf
  libwebkitgtk-1.0-0 libmad0 python-support libdirac-encoder0 libsvn-perl libvcdinfo0 libebml3
  libmpcdec6 libcrystalhd3 libmpeg2-4 libxcb-randr0
Use 'apt-get autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 695 not upgraded.
This is the output of sudo apt-cache policy libglapi-mesa:
$ sudo apt-cache policy libglapi-mesa
libglapi-mesa:
  Installed: 9.0-0ubuntu1
  Candidate: 9.0-0ubuntu1
  Version table:
 *** 9.0-0ubuntu1 0
        100 /var/lib/dpkg/status
     8.0.4-0ubuntu0.7 0
        500 http://archive.ubuntu.com/ubuntu/ precise-updates/main amd64 Packages
     8.0.4-0ubuntu0.6 0
        500 http://archive.ubuntu.com/ubuntu/ precise-security/main amd64 Packages
     8.0.2-0ubuntu3 0
        500 http://archive.ubuntu.com/ubuntu/ precise/main amd64 Packages
And I have read How do I resolve unmet dependencies after adding a PPA?, but that does not solve my problem.
n179911
  • 641
I don't know why you have a newer version of libglapi-mesa, but that's not right. You need to downgrade the package (and maybe others) to fix the issue:
sudo apt-get install -f libglapi-mesa=8.0.4-0ubuntu0.7
It will probably tell you that you need to downgrade other packages, answer "Y".
Braiam
  • 69,112
