I downloaded the linux build of Super Hot, I'm kinda new to Ubuntu, so I have no idea what to do with the files I've just downloaded... It's a zip file, I extracted it to my desktop, and there were a file with a long name and a x86 extension, I renamed it to SUPERHOT.x86 if I would need to use a terminal... I opened up the file and it started extracting .part2 files to the folder... I have no idea what to do next.... Link for page:
http://superhotgame.com/play-prototype
Direct Download:
http://superhotgame.com/SUPERHOT_Prototype_Linux.zip
Go to the folder you extracted it to in the terminal, and just run it:
cd Linux
./SUPERHOT\ September\ 2013.x86
(Or whatever you renamed it to.) Ran fine on my system. I didn't see any .part2 files being extracted anywhere.
To get to a terminal, press CtrlAltT. Navigate to your Desktop by typing these commands and pressing enter:
cd ~/Desktop/Linux
./SUPERHOT.x86
muru
  • 207,228
You can download SUPERHOT here and after downloading, rename the file to "SUPERHOT.run"
Open your terminal then run these commands (per line):
cd ~/Downloads
chmod +x "SUPERHOT.run"
./"SUPERHOT.run"
If you're using 64-bit os and there's an error like mine:libfuse.so.2:cannot open shared object file, follow this:
  1. Install 32-bit libraries
    sudo apt-get update
    sudo apt-get install libc6-i386 libglib2.0-0:i386
  2. Install 32-bit libfuse package
    pushd /tmp/
    wget http://archive.ubuntu.com/ubuntu/pool/main/f/fuse/libfuse2_2.8.1-1.1ubuntu2_i386.deb
    ar x libfuse2_2.8.1-1.1ubuntu2_i386.deb data.tar.gz
    tar -xhf data.tar.gz ./lib/libfuse.so.2.8.1
    sudo install -o root lib/libfuse.so.2.8.1 /lib32/libfuse.so.2
    rm lib/libfuse.so.2.8.1 data.tar.gz libfuse2_2.8.1-1.1ubuntu2_i386.deb
    rmdir lib
    sudo ldconfig
    popd
  3. Run the SUPERHOT
    cd ~/Downloads
    ./"SUPERHOT.run"
    or you can just double-click the file if you already ran the above code.
That should work.
newbieguy
  • 181
Download SUPERHOT, unzip the file, then open the folder it made "Linux" right-click SUPERHOT September 2013.x86 go to properties and under the permissions tab click "allow file executing as program". From there you should be able to open the games just by double clicking the SUPERHOT September 2013.x86 file.
Graphical way
  1. Download the file (You already did that, good!)
  2. Extract both SUPERHOT September 2013_Data folder and the executable file SUPERHOT September 2013.x86 to the same location.
  3. Right click on the executable file, click Properties. A window will appear. Select Permissions tab. Check Allow executing file as program. Close the dialog.
  4. Double lick to launch.
Automated installation (script that does same steps, just automatically):
Save this script as superhot_installation.sh, make it executable with chmod +x superhot_installation.sh , run as ./superhot_installation.sh
#!/bin/bash
mkdir ~/Desktop/SUPERHOT
cd ~/Desktop/SUPERHOT
wget http://superhotgame-new.azurewebsites.net/BUILDS/SUPERHOT_Prototype_Linux.zip
unzip SUPERHOT_Prototype_Linux.zip
chmod +x "$HOME/Desktop/SUPERHOT/Linux/SUPERHOT September 2013.x86"
echo 'Done'
If you want to create a shortcut for the game, visit the question: How can I create launchers on my desktop?
