i've run this bellow command
sudo apt-get install openssh-server
getting bellow errors
Reading package lists... Done
Building dependency tree
Package openssh-server is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'openssh-server' has no installation candidate
I also tried with
/etc/init.d/ssh restart
got response as,
bash: /etc/init.d/ssh: No such file or directory
A J
  • 11,557
This is because 11.10 went End Of Life a year or so ago - it would be much better to upgrade to a newer release like 14.04, which is available from here.
An alternative would be to download the packages you need from http://packages.ubuntu.com - e.g. openssh-server server can be found here.
You will likely also need to download some the dependencies as well (highlighted with the red dot - you may have some/most installed anyway).
A much better method than downloading the packages would be to use the method that can be found here:
How to install software or upgrade from an old unsupported release?
Wilf
  • 30,732
