I'm a new Ubuntu user. I've installed Ubuntu 13.10 on my desktop alongside windows 7.
When I try to play any mp3 file with Parole Media player (which I believe is the default) , it says :
Parole needs MPEG-1 Layer 3(MP3) decoder to play this file. It can be installed automatically.
Then I click Install and it gives error like Required plug-in could not be found.
Even when I am connected to the Internet .
I read many solutions on this very forum , but none of them seemed to work .
The last thing I tried was to manual download and install the MP3 plug-in package . It installed successfully, but I still can't play Music.
belacqua
  • 23,540
You need to enable the Ubuntu Partner Archives and install the Fluendo MP3 plugin.
You may also want to install Ubuntu-Restricted-Extras, which includes LAME. LAME generally provides better MP3 compression.
I have used Parole in Ubuntu before. Although its from Xubuntu/XFCE but it works flawlessly on Ubuntu. To solve all the codec problems you need to install ubuntu-restricted-extras package.
For this you will have to enable universal repository (if you haven't already). If you don't have it enabled, go to "Software & updates" from dash or Settings. Then check all the checkboxes (except sources) and click Close. Then do one of the following:
  1. Open the Ubuntu Software Center and search for "Ubuntu Restricted Extras" and install it.
  2. If you don't mind using the terminal here's what you should run:
sudo apt-get update && sudo apt-get install ubuntu-restricted-extras
And you should have the problem solved.
Adnan
  • 29
