Hi while trying to get the drivers for my "EDIMAX AC600 Dual-Band High Gain Wi-Fi USB Adapter" I run into the following problem:
After sudo apt-get install build-essential
and cd /home/"USERNAME"
I try to tar vxzf rtl8812AU_linux_v4.2.0_6952.20130315.tar.gz
but I get:
tar (child): rtl8812AU_linux_v4.2.0_6952.20130315.tar.gz: Cannot open: No such file or directory
tar (child): Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error is not recoverable: exiting now
as result
I can't find the folder where it is supossed to be, the sudo apt-get doesn't show me where it put it.
I am Running Xubuntu and I'm totally new to it, borrowed that laptop a week ago for my travels.
Thank your for you attention
Charles Green
  • 21,859
Simply copy and paste each command:
sudo apt-get install build-essential git
git clone https://github.com/gnab/rtl8812au.git
cd rtl8812au
make
sudo make install
sudo modprobe 8812au
You should be all set.
You have compiled the driver for your current running kernel only. When Update Manager installs a later one, also known as linux-image, re-compile:
cd ~/rtl8812au
make clean
make
sudo make install
Glad it's working!
chili555
  • 61,330
Now this driver has been added to Ubuntu repositories.
It can be installed to Ubuntu 15.10 and 16.04 by running
sudo apt-get install rtl8812au-dkms
The current version is 4.3.8.
Pilot6
  • 92,041
Special note! :D I have D-Link AC1200 USB adapter. It's a Revision D tho!!! So I kept digging and digging... turns out, revision C had a different chip, than mine! So for those of you digging that can't get yours working,
OR if you know you have a Realtek RTL8812BU or RTL8822BU chipset, then try the following 1 line at a time in your command prompt. Worked for me and I'm so stoked right now! :D :) I had to dig and dig tho, so I thought I would drop this gem here since all my searches for DWA 182 d1 led me here at one point or another. Hope this helps someone. :)
sudo apt update
sudo apt install -y git
git clone https://github.com/EntropicEffect/rtl8822bu.git
cd rtl8822bu
make
sudo make install
sudo modprobe 88x2bu
