I am trying to get a usb wireless device working on ubuntu, sadly when it gets plugged in it seems to come up as a storage device rather than an interface.
I have tried installing numerous drivers from many different sources (to list a some):
This is the output of the lsusb command:
Bus 003 Device 006: ID 0bda:c811 Realtek Semiconductor Corp.
dmesg output on plugging in the usb:
[  +0.000666] usb-storage 3-2.4:1.0: USB Mass Storage device detected
[  +0.000209] scsi host2: usb-storage 3-2.4:1.0
[  +1.020215] scsi 2:0:0:0: Direct-Access     Realtek  Driver Storage   1.00 PQ: 0 ANSI: 0 CCS
[  +0.000585] sd 2:0:0:0: Attached scsi generic sg1 type 0
[  +0.000411] sd 2:0:0:0: [sdb] 16000 512-byte logical blocks: (8.19 MB/7.81 MiB)
[  +0.002656] sd 2:0:0:0: [sdb] Write Protect is off
[  +0.000003] sd 2:0:0:0: [sdb] Mode Sense: 03 00 00 00
[  +0.002631] sd 2:0:0:0: [sdb] No Caching mode page found
[  +0.000010] sd 2:0:0:0: [sdb] Assuming drive cache: write through
dmesg output on command sudo usb_modeswitch -KW -v 0bda -p 1a2b
  +0.009662]  sdb:
[  +0.006413] sd 2:0:0:0: [sdb] Attached SCSI removable disk
[Jul 7 10:05] usb 3-2.4: USB disconnect, device number 7
[  +0.223896] usb 3-2.4: new high-speed USB device number 8 using xhci_hcd
[  +0.106195] usb 3-2.4: New USB device found, idVendor=0bda, idProduct=c811
[  +0.000003] usb 3-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  +0.000002] usb 3-2.4: Product: 802.11ac NIC
[  +0.000002] usb 3-2.4: Manufacturer: Realtek
[  +0.000001] usb 3-2.4: SerialNumber: 123456
modinfo:
$ modinfo 8812au
filename:       /lib/modules/4.15.0-109-generic/updates/dkms/8812au.ko
version:        v4.3.8_12175.20140902
author:         Realtek Semiconductor Corp.
description:    Realtek Wireless Lan Driver
dkms status:
rtl8812au, 4.3.8.12175.20140902+dfsg, 4.15.0-109-generic, x86_64: built
rtl8812au, 5.6.4.2, 4.15.0-109-generic, x86_64: installed
rtl8812au, 5.6.4.2, 4.15.0-99-generic, x86_64: installed
Does anyone have any idea what I am doing wrong? I am not the best when it comes to drivers so I could be doing something... very silly...?
Zanna
  • 72,312
TheHidden
  • 101
