I am having Ubuntu 14.04 LTS. While trying to install crossvc, I am getting broken package error.
I tried to find solutions and tried all the suggested steps in different posts. But no success.
  • LOGS for sudo apt-get install crossvc
    Reading package lists... Done
    Building dependency tree
     crossvc : Depends: libqt3-mt (>= 3:3.3.8-b) but it is not installable
  • LOGS for sudo aptitude install crossvc
    The following NEW packages will be installed:
      crossvc{b} libfam0{a}
    0 packages upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
    Need to get 1300 kB of archives. After unpacking 4048 kB will be used.
     crossvc : Depends: libqt3-mt (>= 3:3.3.8-b) which is a virtual package.
    The following actions will resolve these dependencies:
         Keep the following packages at their current version:
    1)     crossvc [Not Installed]
    Accept this solution? [Y/n/q/?] n
    *** No more solutions available ***
  • LOGS when installing using Ubuntu Software Center
    Package dependencies cannot be resolved
    This error could be caused by required additional software packages which are missing or not installable. Furthermore there could be a conflict between software packages which are not allowed to be installed at the same time.
    Details:
    crossvc: Depends: libc6 (>= 2.4) but 2.19-0ubuntu6 is to be installed
             Depends: libgcc1 (>= 1:4.1.1) but 1:4.9-20140406-0ubuntu1 is to be installed
             Depends: libqt3-mt (>= 3:3.3.8-b) but it is not going to be installed
             Depends: libstdc++6 (>= 4.2.1) but 4.8.2-19ubuntu1 is to be installed
  • Other option tried
    Even I tried with doing the below for resolving broken package [referred from different posts] but no success.
    sudo dpkg --configure -a
    sudo apt-get clean && sudo apt-get update
    dpkg --get-selections | grep hold [ no package listed ]
user.dz
  • 49,176
Satish
  • 13
libqt3-mt is old Qt3 deprecated lib in favor of Qt4. It is available only in Lucid and Precise repositories:
http://packages.ubuntu.com/search?keywords=libqt3-mt
  1. Download Precise package from (choose a mirror):
    http://packages.ubuntu.com/precise/libqt3-mt
    Example, 64bit:
    wget http://de.archive.ubuntu.com/ubuntu/pool/main/q/qt-x11-free/libqt3-mt_3.3.8-b-8ubuntu3_amd64.deb
    32Bit:
    wget http://de.archive.ubuntu.com/ubuntu/pool/main/q/qt-x11-free/libqt3-mt_3.3.8-b-8ubuntu3_i386.deb
  2. Install it, 64bit::
    sudo dpkg -i libqt3-mt_3.3.8-b-8ubuntu3_amd64.deb
    32bit:
    sudo dpkg -i libqt3-mt_3.3.8-b-8ubuntu3_i386.deb
Try with crossvc again. It should work as I have tested it in my Ubuntu 14.04.
Still missing some dependencies, Search using http://packages.ubuntu.com/:
user.dz
  • 49,176
// installing it on 32 bit
$ wget http://security.ubuntu.com/ubuntu/pool/multiverse/c/crossvc/crossvc_1.5.2-2_i386.deb
$ sudo dpkg -i crossvc_1.5.2-2_i386.deb
// 64 bit
$ wget http://security.ubuntu.com/ubuntu/pool/multiverse/c/crossvc/crossvc_1.5.2-2_amd64.deb
$ sudo dpkg -i crossvc_1.5.2-2_amd64.deb
// if that didnt workout with you you should wait for the next version of it
its not apt problem its repository prob
hwez
  • 3,026
