I tried to disable the wireless functions at boottime like Lekensteyn described here: How can I keep a wireless card's radio powered off by default?
But it keeps starting enabled after a reboot!
I added the command to /etc/rc.local by running
sudo nano /etc/rc.local
Used the arrow keys / page up/down keys to navigate to the line before exit 0 and add rfkill block wifi, so that the file end like this:
# By default, this script does nothing
rfkill block wifi
# for debugging:
rfkill list > /tmp/wifi-state.txt
exit 0
Now in /tmp/wifi-state.txt I can see that it was blocked right after the call in rc.local But if I call
rfkill list
on the console, it shows that WiFi is enabled again:
0: phy0: Wireless LAN
    Soft blocked: no
    Hard blocked: no
1: hci0: Bluetooth
    Soft blocked: yes
    Hard blocked: no
Additional info: I added this to disable bluetooth it works fine:
rfkill block bluetooth
and
sudo rfkill block wifi
works fine on the console
rubo77
  • 34,024
  • 52
  • 172
  • 299
You can try to use ifconfig instead...
Add the following to rc.local
$> ifconfig wlan0 down
If you suspend/hibernate your computer the you will have to add the same to the suspend process as well.
Create a file by
$> sudo nano /etc/pm/sleep.d/20_custom_wlan0
add the following to the file.
# Script to disable wlan0 before suspend and restart after wake.
case "${1}" in
        suspend|hibernate)
                echo suspending wlan0
        resume|thaw)
               echo Resuming wlan0 - shutting down wlan0
               ifconfig wlan0 down
esac
save the file and make sure is executable by
That should do the trick.
By the way the name of the filename doesn't matter so much except it must start with something below 60 as number decide where in the process the file is run. And some system have 60 staring the network card after suspend. Look in the /etc/pm-suspend.log file.
I solved it with this quite "hacky" solution: a sleep 10 delay: It seems like in Ubuntu 14.04 you need to wait some seconds before you disable wifi in /etc/rc.local.
Use this instead:
Use the arrow keys / page up/down keys to navigate to the line before exit 0 and add /bin/sleep 10 && rfkill block wifi, so that the file will look like this:
exit 0
The other solution above suppose to be the cleaner one, but that one doesn't always work...
rubo77
  • 34,024
  • 52
  • 172
  • 299
I solved it (on my Lenovo Yoga 2 Pro) with this solution instead: edit the file
and add two lines, so that the file will look like this:
# disable wifi:
sed s/^WirelessEnabled=true/WirelessEnabled=false/ -i /var/lib/NetworkManager/NetworkManager.state
rfkill block wifi
exit 0
Note: If you only add the first sed line, it doesn't always work: every now and then my laptop unexpectedly booted with wifi enabled agian, but with both commands it works.
rubo77
  • 34,024
  • 52
  • 172
  • 299
