I'm trying to install Acire and Python Snippets in Ubuntu 11.04 (64-bit).
I have successfully installed Acire, but I'm unable to install the python-snippets package. Both PPA's have been added to my sources list, but when I run sudo apt-get update, I get the error:
W: Failed to fetch http://ppa.launchpad.net/python-snippets-drivers/python-snippets-daily/ubuntu/dists/natty/main/binary-amd64/Packages  404  Not Found
What should I do to install python-snippets?
JLinden
  • 1,030
If you are talking about this PPA - https://launchpad.net/~python-snippets-drivers/+archive/python-snippets-daily - there are packages only for Lucid and Maverick. No packages yet for Natty.
Suggest either contact the package owner (one Jorge O Castro!) or try editing your software sources and changing "natty" to "maverick" as per this AU answer
fossfreedom
  • 174,526
There is also another PPA with the python-snippets package built specifically for Natty.The only place I could find one that was suitable for Natty was in Matthieu Baerts’ PPA. You can add the source and install python-snippets with the following commands:
sudo add-apt-repository ppa:matttbe/ppa
sudo apt-get update
sudo apt-get install python-snippets
After this Acire does have a dependency on the desktopcouch package. You can get the desktopcouch package from the Software center or use the following command:
sudo apt-get install desktopcouch
Now you should have all the packages you need. you can run Acire from the command line by just typing “acire” It should also appear on your menu, in the programming category. If you are using unity you should be able to use the main lens to find and run Acire.
