I am trying to make a simple screencasting bash script. I want to get screen selection coordinates by drawing a red rectangle with mouse. I can use xdotools to get coordinates but how can I draw rectangle on screen?
kenn
  • 5,232
I just found https://www.opengl.org/discussion_boards/showthread.php/157014-Compiling-with-gcc, and I modified the code to get rid of the 100% CPU hog; it seems to work fine on Ubuntu 14.04 - simply run it from a terminal, draw your rectangle area, and the program will exit, printing the coordinates in the terminal:
xrectsel.c:
#include<stdio.h>
#include<stdlib.h>
#include<X11/Xlib.h>
#include<X11/cursorfont.h>
#include<unistd.h> // added for sleep/usleep
// original from [https://bbs.archlinux.org/viewtopic.php?id=85378 Select a screen area with mouse and return the geometry of this area? / Programming & Scripting / Arch Linux Forums]
// build with (Ubuntu 14.04):
// gcc -Wall xrectsel.c -o xrectsel -lX11
int main(void)
  int rx = 0, ry = 0, rw = 0, rh = 0;
  int rect_x = 0, rect_y = 0, rect_w = 0, rect_h = 0;
  int btn_pressed = 0, done = 0;
  XEvent ev;
  Display *disp = XOpenDisplay(NULL);
  if(!disp)
    return EXIT_FAILURE;
  Screen *scr = NULL;
  scr = ScreenOfDisplay(disp, DefaultScreen(disp));
  Window root = 0;
  root = RootWindow(disp, XScreenNumberOfScreen(scr));
  Cursor cursor, cursor2;
  cursor = XCreateFontCursor(disp, XC_left_ptr);
  cursor2 = XCreateFontCursor(disp, XC_lr_angle);
  XGCValues gcval;
  gcval.foreground = XWhitePixel(disp, 0);
  gcval.function = GXxor;
  gcval.background = XBlackPixel(disp, 0);
  gcval.plane_mask = gcval.background ^ gcval.foreground;
  gcval.subwindow_mode = IncludeInferiors;
  GC gc;
  gc = XCreateGC(disp, root,
                 GCFunction | GCForeground | GCBackground | GCSubwindowMode,
                 &gcval);
  /* this XGrab* stuff makes XPending true ? */
  if ((XGrabPointer
       (disp, root, False,
        ButtonMotionMask | ButtonPressMask | ButtonReleaseMask, GrabModeAsync,
        GrabModeAsync, root, cursor, CurrentTime) != GrabSuccess))
    printf("couldn't grab pointer:");
  if ((XGrabKeyboard
       (disp, root, False, GrabModeAsync, GrabModeAsync,
    printf("couldn't grab keyboard:");
  // see also: http://stackoverflow.com/questions/19659486/xpending-cycle-is-making-cpu-100
  while (!done) {
    //~ while (!done && XPending(disp)) {
      //~ XNextEvent(disp, &ev);
    if (!XPending(disp)) { usleep(1000); continue; } // fixes the 100% CPU hog issue in original code
    if ( (XNextEvent(disp, &ev) >= 0) ) {
      switch (ev.type) {
        case MotionNotify:
        /* this case is purely for drawing rect on screen */
          if (btn_pressed) {
            if (rect_w) {
              /* re-draw the last rect to clear it */
              XDrawRectangle(disp, root, gc, rect_x, rect_y, rect_w, rect_h);
            } else {
              /* Change the cursor to show we're selecting a region */
              XChangeActivePointerGrab(disp,
                                       ButtonMotionMask | ButtonReleaseMask,
                                       cursor2, CurrentTime);
            rect_x = rx;
            rect_y = ry;
            rect_w = ev.xmotion.x - rect_x;
            rect_h = ev.xmotion.y - rect_y;
            if (rect_w < 0) {
              rect_x += rect_w;
              rect_w = 0 - rect_w;
            if (rect_h < 0) {
              rect_y += rect_h;
              rect_h = 0 - rect_h;
            /* draw rectangle */
            XFlush(disp);
          break;
        case ButtonPress:
          btn_pressed = 1;
          rx = ev.xbutton.x;
          ry = ev.xbutton.y;
          break;
        case ButtonRelease:
          done = 1;
          break;
  /* clear the drawn rectangle */
  if (rect_w) {
    XFlush(disp);
  rw = ev.xbutton.x - rx;
  rh = ev.xbutton.y - ry;
  /* cursor moves backwards */
  if (rw < 0) {
    rx += rw;
    rw = 0 - rw;
  if (rh < 0) {
    ry += rh;
    rh = 0 - rh;
  XCloseDisplay(disp);
  printf("%dx%d+%d+%d\n",rw,rh,rx,ry);
  return EXIT_SUCCESS;
sdbbs
  • 1,684
  • 19
  • 27
you can install python cli package
pip3 install python-xrectsel
Check format options
xrectsel --help
user957086
  • 31
