I tried to set up broadband Internet connection, started as I found in this question
sudo pppoeconf
and shown that wifi was disabled.
Sorry, I scanned 2 interfaces, but the Access Concentrator of your provider did not respond. Please check your network and modem cables. Another reason for the scan failure may also be another running pppoe process which controls the modem.
and the result found below my command was
SIOCSIFFLAGS: Operation not possible due to RF-kill
If the same command runs after enabling wifi, no result is showing in terminal.
Then I tried another command
sudo ifconfig
And got this result:
eth0      Link encap:Ethernet  HWaddr 20:89:84:ea:68:5d
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
          Interrupt:16
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:8947 errors:0 dropped:0 overruns:0 frame:0
          TX packets:8947 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:961374 (961.3 KB)  TX bytes:961374 (961.3 KB)
wlan0     Link encap:Ethernet  HWaddr 48:d2:24:3f:4f:3e
          inet addr:192.168.59.104  Bcast:192.168.59.255  Mask:255.255.255.0
          inet6 addr: fe80::4ad2:24ff:fe3f:4f3e/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:241942 errors:0 dropped:0 overruns:0 frame:0
          TX packets:173747 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:338342037 (338.3 MB)  TX bytes:18314966 (18.3 MB)
Can anyone please explain to me what the is problem and what steps I should follow to resolve it?
If you're setting up for BSNL, Network Manager does not support PPP connection over WiFi as of now. And it probably never will.
You need to edit a file and then run a command to start a connection. Edit /etc/ppp/peers/provider and add these lines:
plugin rp-pppoe
wlan1
user "username"
noipdefault
usepeerdns
defaultroute
replacedefaultroute
noauth
persist
hide-password
You must replace wlan1 with the name of your wireless interface. Use the iwconfig command to find out. In your case it could be wlan0. Replace "username" (keep the quotes here) with your login username provided by the ISP.
Then edit /etc/ppp/chap_secrets:
# Secrets for authentication using CHAP
# client    server  secret          IP addresses
username *      password
Again, replace username and password with login details from your ISP (no quotes here).
If you're unsure of how to edit them, use sudo -H gedit <filename> to edit both files.
Then use the command pon to start a connection and poff -a to stop all connections when you're done. Use plog to check the status of the connection.
If you are using Network Manager to connect to WiFi, you can get it to start a connection automatically when the WiFi is connected. In a terminal, type:
sudo grep -i uuid /etc/NetworkManager/system-connections/*
You will see a list of files with UUIDs listed. Copy the UUID for your WiFi connection (e.g. 44f15a85-2c11-453d-b557-385ba3a5bb84). Do sudo -H gedit /etc/NetworkManager/dispatcher.d/10-ppp.sh and add these lines:
#! /bin/bash
if [[ $CONNECTION_UUID == '44f15a85-2c11-453d-b557-385ba3a5bb84' ]]
then
    case $1 in
    up)
        while pgrep ppp >/dev/null
        do
            poff -a
        done
        pon
    down)
        do
            poff -a
        done
    esac
fi
After saving the file, execute these commands:
sudo chown root /etc/NetworkManager/dispatcher.d/10-ppp.sh
sudo chmod 744 /etc/NetworkManager/dispatcher.d/10-ppp.sh
You have to do this because dispatcher scripts have to be owned by root and not writable by anybody else but the owner, and should be executable.
Here's the annoying bit: If the Wireless connection goes down suddenly, when it gets reconnected, ppp won't be able to reconnect for a couple of minutes or more. You may even have to restart ppp manually by doing poff -a; pon a couple of times. You'll know the connection has been established when plog shows the IP address you have been assigned.
muru
  • 207,228
