-1
I am pretty new to ubuntu, 2 days back I installed Ubuntu 12.04 in widows. I was told that 12.04 is very obsolete version. so I deleted (literally Ctrl+Shift+Del) Ubuntu directory and downloaded and installed Ubuntu 14.04. Now the problem is when I start the computer, I see a prompt whether I want to boot in Windows or Ubuntu, but when I select Ubuntu it shows some error message - obviously since I have deleted the files. But I am not able to see the prompt for Ubuntu 14.04.
Please help. If you need more information regarding this I'll give it in comments.
Short:
Forget about Wubi, restore Windows bootloader, prepare partitions and install Ubuntu 14.04 in a normal way.
Detailed:
Boot from Windows 7 DVD and after choosing language options, start the console: Repair your computer -> Use recovery tools... -> Command prompt. In the console run the following commands to re-install Windows bootloader:
bootrec /fixmbr
bootrec /fixboot
Reboot and that's it! Now You should have only normal Windows bootloader, no mess after Wubi.
Then prepare partitions for Ubuntu. You can shrink Windows NTFS partition under Windows and let the Ubuntu installer use free space, or you can let the installer handle whole process for you. It is wide topic, but is is not very complicated, so there is nothing to worry about. There is no reason to re-write official Ubuntu documentation here, just read and follow Install Ubuntu 14.04 LTS and everything will be clear and easy.
