Whether through update manager, or through terminal, I error out.
When I try sudo apt-get update && sudo apt-get upgrade:
Fetched 1,024 kB in 20s (51.0 kB/s)
Reading package lists... Done
Building dependency tree Reading state information... Done
You might want to run 'apt-get -f install' to correct these.
The following packages have unmet dependencies: linux-headers-generic :
Depends: linux-headers-3.13.0-29-generic but it is not installed
E: Unmet dependencies. Try using -f.
And When I try sudo apt-get -f install:
Unpacking linux-headers-3.13.0-29-generic (3.13.0-29.53) ...
dpkg: error processing archive /var/cache/apt/archives/linux-headers-3.13.0-29-generic_3.13.0-29.53_amd64.deb
(--unpack): unable to create /usr/src/linux-headers-3.13.0-29-generic/include/config/inotify/user.h.dpkg-new' (while processing./usr/src/linux-headers-3.13.0-29-generic/include/config/inotify/user.h'): No space left on device
No apport report written because the error message indicates a disk full error dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Errors were encountered while processing: /var/cache/apt/archives/linux-headers-3.13.0-29-generic_3.13.0-29.53_amd64.deb
When I open Ubuntu software center, I get the following text:
New software can't be installed because there is a problem with the software currently installed. Do you want to repair this problem now?
I get the option to 'repair' or 'cancel'. If I hit 'repair', I get the following error:
Package operation failed
the installation or removal of a software package failed.
(Reading database ... 417598 files and directories currently installed.)
Preparing to unpack .../linux-headers-3.13.0-29-generic_3.13.0-29.53_amd64.deb ... Unpacking linux-headers-3.13.0-29-generic (3.13.0-29.53) ...
(--unpack): unable to create /usr/src/linux-headers-3.13.0-29-generic/include/config/bug.h.dpkg-new' (while processing./usr/src/linux-headers-3.13.0-29-generic/include/config/bug.h'): No space left on device
Error in function: dpkg: dependency problems prevent configuration of linux-headers-generic: linux-headers-generic depends on linux-headers-3.13.0-29-generic; however: Package linux-headers-3.13.0-29-generic is not installed.
dpkg: error processing package linux-headers-generic (--configure): dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of linux-generic: linux-generic depends on linux-headers-generic (= 3.13.0.29.35); however: Package linux-headers-generic is not configured yet.
dpkg: error processing package linux-generic (--configure): dependency problems - leaving unconfigured
The disk full error is odd, because none of my disks are full. I know this because when I run df, I get the following:
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda6 36178648 13162504 21155332 39% /
none 4 0 4 0% /sys/fs/cgroup
udev 3873544 12 3873532 1% /dev
tmpfs 776860 1384 775476 1% /run
none 5120 0 5120 0% /run/lock
none 3884300 25276 3859024 1% /run/shm
none 102400 68 102332 1% /run/user
/dev/sda2 124327968 42583252 81744716 35% /media/sudoer/48AEC994AEC97B48
/dev/sda3 807468724 121812996 685655728 16% /media/sudoer/New Volume
What do I do at this point? Thanks in advance.
